I am hoping that the 2 Questions I have are proper for this  forum/section. The reason I am posting these in the Aprilla Forums, even  though many boards exist for discussing advanced motorcycle skills, is  that I found the discussion here very intelligent and insightful. So  here it goes and thanks to all in advance for the input.
1. COUNTER-STEERING
I have been, as of today, riding for a month; so very new rider here.  However, I am very interested in automobile advanced driving techniques  and physics of motoring in general and did a lot of reading and research  before beginning to ride full time. I also took the MSF Beginners  Course where they make a half-hearted attempt at teaching  counter-steering. After riding for a week and thinking that I was  properly counter-steering, however, I set a day aside to really dig into  this concept and I found that, I was not counter-steering really. I was  still muscling the bike (a 125 CC mini race-type bike, by the way) into  turns. After a few attempts of applying no downward pressure on the  handlebars and really pushing FORWARD on the bar on the side I wanted to  turn and confidently letting the bike do the rest, I realized that this  is indeed frikkin magic!!! How effortless the bike leans and turns  still boggles my mind.
Unlike most new riders, however, I am finding that counter-steering is  working too well. When I perform it on public roads in the manner  described above, I feel like the front end of the bike is almost  floating, or gliding so easily as if it were on ice, and I am fearful of  the bike suddenly leaning too much. I realized that this fear is making  me steer very slowly and gradually into turns. When I see a bend, I am  very slowly countersteering and it takes me a good amount of road to  lean the right amount (even if it is a relatively minor turn) that is  appropriate for the turn. This may sound strange but I caught myself  doing this many times over the last couple weeks. It is annoying and  almost dangerous too. A few times I realized I wasn't looking ahead far  enough and when I saw a turn coming up shortly I had a hard time getting  into the right lean angle on time -mind you this happened even when I  didn't need any space to brake and reduce my speed (my speed was already  suited for the corner coming up). Of course I also need to make it a  habit to look well ahead, but I should still correct this bad, bad habit  of very slow steering, I'd think, no?
Would you all have any suggestions for this at all?
2. ClutchLess Shifting
This question is more to satisfy my curiosity as opposed to a real problem; though I'd love to know what you think about it.
In autos I enjoyed shifting without the clutch when appropriate and I  was super happy when I realized that it is even easier to do on a  motorcycle. I am able to shift both up and down relatively smoothly  (depending on the gear; for example clutchless upshifts from 2nd to 3rd  are generally butter smooth -even smoother than when I am using the  clutch for the same shift at the same speed) without using the clutch. I  am basically unloading the drive-train momentarily by closing the  throttle and shifting the gear at exactly the moment when the throttle  is maximally closed (by that I mean as closed as the throttle needs to  be closed for that particular clutchless shift); not sure if this is the  best way, but so far it is working fine on this weakass bike. On  downshifts I am blipping the throttle following the closing phase of the  clutch too. I am doing this to avoid engine braking (no slipper clutch  on my cheapy bike of course).
My question is whether mastering clutchless shifting in the manner  described above could work in a high performance motorcylcle on a  roadcourse. Would the downshifts that I am describing above work  reliably enough that one would not have to use the clutch? Or would the  above technique still lock or severely brake the rear tire occasionally  if done on a track with a powerful bike, thus making it too risky to  rely on as a routine race technique?
