R6 seat 2007- new, $20
R6 Wheels 06-11- $100 each
1 Front, straight, no rotors
1 Rear, straight- rotor, 520 sprocket and cush included
1 Rear, straight, no rotor, but 520 sprocket and cush included
R6 Pistal lightweight, high compression pistons, stock bore 06-11- $400, I was told these were a matched set from a Yamaha supported WSS team, and everything about them leads me to believe it’s true. Two of them are used very slightly (for dyno runs only is what I was told), and the other two are new. I thought I had these installed in my motor, but their presence on my shelf indicates otherwise. These would be a great alternative to a high commitment big bore motor. Pins are included. These retail, if you can get them, for $1200.
R0045Q-10 Gapless Spark Plugs- these are the best money can buy, normally $70 per plug, $150 for set of 4
Triple tree front stand- $75
Aluminum rear stand- only weighs 6lbs!, so much better than a ridiculously heavy pit bull, $75
Tire Bakers Tire Warmers- standard single temp, well used but work great $100
XT Ultra Lap Timer $75
Fork clamps- I have a 50mm and 52mm $20 each
Traxxion Dynamics fork spring compressor $20
Cardona quickshifter- push style, new never used $150
