Add a new class to create a spec class for the ninja 250 with the following rules:
Class: Ninja 250 cup class
Type: Amateur - Sprint
Bike must be a Kawasaki Ninja 250 (EX250) to qualify for this class. All years of this model are allowed.
In the interest of creating parity in the class ONLY the following modifications are allowed.
1: Bike must comply with safety standards listed in section 5.2.1 EXCEPT that the Ninja 250 does NOT require a steering damper.
2: Bodywork may be replaced with parts of unlimited origin
3: Exhaust system may be replaced with parts of unlimited origin
4: Carburetor jetting may be changed
5: Suspension may be modified with different springs / valves, but the stock rear shock body and stock fork tubes must be retained.
6: Brake lines (hoses) may be replaced with parts of unlimited origin
7: Controls; footpegs, rearsets, handlebars, clip on's, levers may be replaced with parts of unlimited origin. Brake master cylinders and throttle control must remain as stock.
8: Consumables (tires / brake pads) may be replaced with parts of unlimited origin.
9: The stock airbox / air filter must remain in place and connected. No modification of the airbox / air filter is permitted.
