Results 1 to 11 of 11
Thread: 2006 R6r Starting issues
    Jul 2008
    Denver, CO
    148
    Cannot get my 2006 R6 Started...It acts like its gonna then dies...I put fresh fuel in...checked all my grounds..checked the rollover switch.Installed a brand new battery fully charged...Anyone out there know yamahas very well that can come by and help a fellow racer out!! Thank you
    "BADASSES SURVIVE"
    Scarberry Racing Team & PEPPOD race team!
    2011 Sponsors:
    The Dandelion in Boulder, CO
    PEPPOD ENERGY DRINK!
    SCARBERRY MECHANICAL Heating & Plumbing
    VANMAR MICHELIN
    Colorado Powersports
    XBAM!
    VISA!!!!
    2007 Yamaha R6 MRA# 577
    Littleton, Co
    1,659
    Check engine light coming on while you are cranking her over?
    You can go into self-diagnostic mode and test the coils, injectors, etc.
    Let me know if you want me to roll up some day.
    Also, it ran when you got her right? What have you changed since the last time she fired up?
    Jul 2008
    Denver, CO
    148
    Yes the check engine light is on while cranking! She ran when I got her...All I changed is the battery and put fresh fuel in!
    How do you check the injectors and stuff??
    "BADASSES SURVIVE"
    2011 Sponsors:
    VANMAR MICHELIN
    XBAM!
    VISA!!!!
    Littleton, Co
    1,659
    Did you syphon out the fuel or remove the tank?
    It sounds like something is loose maybe from the tank or battery removal. Make sure your fuel pump connections are on solid. Also, make sure the fuel line is fully connected to the nipple. Go over EVERYTHING under there and make sure a connection isn't loose.
    I can't find the diagnostic info online. If you have the service manual, its in there. I usually hit up Brownie for that. If you want me to swing by this weekend some time let me know. I've had my bike torn down to the frame a number of times so I'm sure we can get it figured out.
    Jul 2009
    utah
    221
    Quote Originally Posted by dragos13
    I know very Little but check your safety switches kick stand, tip over, clutch ect you might get lucky and it can just be a bad connection on one of them!! and +1 on Brownie
    To start with, I agree with Casey. Something is probably just not hooked up. Can you hear the fuel pump kick on when you first turn the key on?
    If you want I can swing by and give you hand. And yes I do have the Service manual if you need it.
    I doubt it is a kickstand, safety switch, as that would not let you turn the motor over at all.
    Jul 2008
    Denver, CO
    148
    Well I finally pulled the fault code 14 called copow and they said it was the intake pressure hose is not connected or pinched so I'm gonna check it tonight!
    "BADASSES SURVIVE"
    2011 Sponsors:
    VANMAR MICHELIN
    XBAM!
    VISA!!!!
    Jul 2008
    Denver, CO
    148
    "BADASSES SURVIVE"
    2011 Sponsors:
    VANMAR MICHELIN
    XBAM!
    VISA!!!!
    1,829
    Gotta love these modern bikes they tell you what's wrong so it's most always a simple fix, you just can't be a simpleton. I've diagnosed a bike on the starting grid and fixed it before the race started.
    Senior Member Expert marty's Avatar
    Dec 2006
    arvada, co
    596
    Quote Originally Posted by Jon
    hear that! hell ive worked on one of my slow ass bikes down the back strait at pmp :lol:
    RS 125
    TZ 250
    #738
    Jul 2008
    Denver, CO
    148
    Figured her out!! I did the smog block off plates..Took off all that crap you dont need and hit the start button and BOOMM shes hummin!! Thanks everyone for your help!!
    "BADASSES SURVIVE"
    2011 Sponsors:
    VANMAR MICHELIN
    XBAM!
    VISA!!!!
  1. GO PRO ISSUES
    By shortie171 in forum General Discussion
    Last Post: June 22nd, 2013, 12:14 PM
  2. TEKNIC suits starting at 315.00 shipped!!!
    By LMsports in forum Supporting Vendor Ads
    Last Post: September 22nd, 2010, 07:16 PM
  3. Starting Lights Visibility at HPR
    By dirkterrell in forum Rules & Tech
    Last Post: June 11th, 2009, 03:55 PM
  4. New bodywork starting at 340.00
    By RCR_531 in forum Parts For Sale
    Last Post: November 18th, 2008, 11:30 PM
  5. Not starting from scratch
    By Jim 'smooth' Brewer in forum MRA Marketing & PR
    Last Post: February 2nd, 2008, 01:31 PM
