Results 1 to 15 of 15
Thread: 2021 Rule Change Suggestions
    Mohammer Time! Expert
    Aug 2005
    1,253
    2021 Rulebook suggestions
    Suggestions for the 2021 Rulebook
    Suggestions for the 2021 rulebook are now open and will be accepted until Wednesday September 30th, 2019 (rules suggestions will not be accepted after 23:59hrs on September 30th). Once the list is compiled, the proposed rule changes will be sent out to all members. Rule changes can be submitted to Shannon, Nyles, or any rider representative. The preferred method would be for racers to submit rule changes via the rule change thread on the MRA forums.
    We've changed the venue and scenery for the rule change meeting over the last few years, so I am up for suggestions on where to have it, but I am leaning towards class sponsor the Nite Owl. The rule change meeting will most likely take place in December (COVID19 may change things).
    The rule change meeting is open to all members and will be held to discuss the proposed 2021 rule changes. The members attending this meeting will be encouraged to give input on the changes that will be presented to the MRA board for approval. Finalized rule changes for the 20201 season should firmed up a few weeks after the meeting.
    When making your suggestion, be sure to cite the existing rule and what changes you are suggesting. If it is a new rule, please use the exact wording as you would like it to appear at the rule change meeting and possibly the rulebook.
    If you want to discuss your rule change proposal, please start a separate thread on the forum.
    If you have any questions please contact Shannon Moham TRKWILLYS@aol.com
    930
    Number Retention Rule 5.3 (C)
    Rule as it is currently written
    1. A racer must participate in 3 or more race weekends of the MRA season events in order to reserve their number for the next season. If they do not participate in 3 or more weekends, their number is considered open and will be given out on a first come, first served basis the following year. The racer may file a request with the board to have their number retained for the next season.
    Reasoning / Thought Process
    I am not sure if a rewording is needed, however I am proposing that this rule be temporarily suspended for the 2021 season. Allowing riders who competed in 2019 the opportunity to renew their license with their existing number. Obviously 2020 has been a little strange due to COVID and think it would be a good idea for those riders wishing to renew in 2021 to be able to retain their numbers without filing a request with the Board.
    We haven’t had a green light for the start of races in many, many years... can we remove all references to “green light“, and replace it with “extinguishing of the red light” or something similar? References to the green flag should probably be kept since that’s the backup in case the light fails.
    Nov 2013
    27
    Suggestions discussed with others, reconsidered, and withdrawn.
    Mar 2010
    675
    Recommended addition to section 7 Race procedures:
    Section 7 - RACE PROCEDURES
    • T. If the race track surface has been deemed wet by MRA officials and a dry racing line is not present throughout the race track, racing will be discontinued immediately. Races will not restart until MRA officials determine a dry racing line is present throughout the race track. If a race is in progress at the point a track surface has been deemed wet, the race will be red flagged, and considered complete. Points for said class will be awarded based on the last completed lap by the entire field. In the case the entire field has not completed at least one lap all riders present on the grid in the class will receive points equal to 1st place finishing position (see section 7.3). Once the track surface has been deemed wet all subsequent races that would have completed determined by MRA Officials during the wet condition will also be considered complete. All riders who are properly regestered in those classes will receive points equal to 1st place finishing position (see section 7.3). At the discretion of MRA Officials, classes with a cash purse maybe exempt from this rule. Riders will not receive a refund for entry fees for any class that was completed due to wet conditions.
    Colorado's Dunlop Tire Vendor
    www.throttleforyourbottle.com
    Thumbs Up! Amateur
    Jul 2012
    Golden
    174
    2.10 Cup Classes
    C. Only petroleum based unleaded pump gasoline is permitted for use. The onlyoxygenates permitted are MTBE and ethanol in the same quantity as found inpump gasolines. If the motorcycle is found using any other oxygenates the ridermay be subject to penalty by disqualification and/or revocation of points. Someof these oxygenates include but are not limited to: propylene oxide, alcohols,aldehydes, aminodiphenyl, benzene, benzidine, beryllium compounds, brominecompounds, butadienes, chlorinated compounds, chromates, dioxanes, ethylacrylate, ethylene oxide, hydrazine compounds, methylene dianailine, methylnaphthalene, naphthalene, naphthylamine, nitrogen compounds, nitro methane,styrenes, toluidine, xylidine. It is highly recommended that if a competitorwishes to use different fuel types for races outside of 350 Cup and 500 Cup thata different fuel tank is used. The rider is liable for ANY residual elements leftover that may be found during testing.
    Proposed change: Remove. Production Cup is a class based on Supersport rules, except for this one clause. If you want to be the idiot spending $40/gallon for +1 hp on your 45hp bike, you should be allowed to. This money saving clause is not going to stop people from racing the class if removed.
    Where the beer flows like wine and the women flock like the salmon of Capistrano, I'm talkin about a little place called... Asssspen!
    MRA #934
    www.carbon-smith.com
    Senior Member Amateur Ducdreamin's Avatar
    May 2014
    133
    2021 Rulebook Suggestions
    1) I think if races are cancelled, they should be treated like the 4-hour endurance for the regular endurance points. If you signed up and are present, you should get points over those who didn't even register and attend the event.
    2) I think that middleweight and heavyweight are redundant classes. I have the only heavyweight bike in the club lol. Eliminate the heavyweight classes - supersport, superbike and endurance. It saves race time, required sponsors and time at the banquet. Contingency for a few is not an excuse for the club to maintain duplicate classes.
    3) Revert Formula 40 to 2 classes instead of 4
    4) 10 minute break between all 3 endurance races (2 breaks)
    5) Eliminate LOR, supermoto and have production cup run on EITHER Saturday OR Sunday, not both
    6) No qualifying for production cup - run it as a normal sprint race
    7) Serious infractions that may result in a letter of reprimand or expulsion should be prefaced with a meeting of the rider representatives. The meeting will explain the issue and the resulting consequences in a face-to-face setting. This can be done at the track or at a location convenient to the rider representatives.
    This was submitted at the end of 2019 but was not implemented correctly. The intention was to mirror the eligible machines in the MotoAmerica Junior Cup series for 14 and 15 year old riders.
    Quote Originally Posted by JimWilson29 View Post
    Current minimum age to be compliant with our liability insurance is 13 years old on a Kawasaki Ninja 300 or smaller only. This also currently includes 14 and 15 year olds. Proposed change below corrects the minimum age and will add additional 300cc and smaller Production Cup motorcycles that 13 year olds are permitted to ride. It will also add additional motorcycles that are currently legal in MotoAmerica Junior Cup for riders with a minimum age of 14.
    Page 27 Section 4 - Rider Qualifications and Advancement
    2019 Rulebook Wording-
    4.4 Overall racer qualifications
    4.4.1 Age
    A. Applicants may be of any age, but must be approved by the New Rider Director.
    B. Applicants less than 18 years of age, and all applicants below the age of majority
    in their home state, must provide a notarized statement of permission from a
    legal parent or guardian.
    C. Admission as a racer will be scrutinized by skill, not by age. However, denial for
    age MAY be a consideration based on specific insurance requirements or track
    limitations. The current minimum age due to insurance requirements is 12 years old.
    D. Rider must pass MRA rider school and permission is still required by legal
    parent or guardian
    Proposed change in 2019
    4.4.1 Age
    limitations. The current minimum age due to insurance requirements is 13 years old
    on 300cc and smaller Production Cup legal motorcycles covered in Section 2.10, and all
    Production Cup legal motorcycles in Section 2.10 for ages 14 and older.
    Age 16 and
    older there are no motorcycle restrictions.
    parent or guardian
    Current rule in 2020 Rulebook now reads-
    4.4.1 Age
    limitations. Admission as a racer will be scrutinized by skill, not by age. However, denial for age
    MAY be a consideration based on specific insurance requirements ortrack limitations.The current
    minimum age due to insurance requirements is 13years of age to compete on any 300cc or less
    motorcycle. Riders 14 years of age and older can compete on the KTM 390.
    parent or guardian
    Proposed change-
    4.4.1 Age
    MAY be a consideration based on specific insurance requirements or track limitations. The current
    minimum age due to insurance requirements is 13 years of age to compete on any 300cc or less
    motorcycle. Riders 14 years of age and older can compete on machines eligible in the Motoamerica
    Junior Cup or equivalent national series. This currently includes the KTM 390/390r, Kawasaki Ninja
    300 and 400, Yamaha YZF- R3 and the Honda CBR500r. This listed of eligible machines can be
    amended
    parent or guardian
    Apr 2010
    Colorado Springs, CO
    381
    Submitted on behalf of Justen Behmer as he does not have access to this board yet.
    Make one day of Production Cup Supersport and the other Superbike. Rational is that Kawasaki (as of this year and guessing next year too), does not pay contingency for Supersport or Superbike for both days of a race weekend, however they will pay contingency for Supersport one day and Superbike the next. Not sure what the other manufactures do, but Kawasaki is the most popular bike on the grid and could potentially benefit more of our racers.
    MRA # 157
    2010 Ducati 1198S
    2009 Indian Chief Roadmaster
    2012 Ducati 796 Monster
    2004 Ducati 749S
    SW Scooternews, Sol Performance/Pirelli, Rudy Project, TYGA Performance, Boulder Motorsports, Woodcraft, Nitron Racing Shocks, Shorai
    Oct 2014
    Thornton CO
    29
    I feel that for Clubman Points, the racer must complete a minimum of 75% of the race unless there is a mechanical or a crash or anyother unforseen stoppage in the race.
    Member Amateur Ice's Avatar
    Jan 2012
    Littleton
    69
    I submit the middleweight Panigale series bikes be entered into Middleweight qualifications (supersport/superbike/endurance). This seems especially pertinent if the heavyweight category is eliminated. It is also in line with USBA rulebook (hyperlink and text below). The bigger mini-Panigale (959) dyno tests ~14HP different from the Daytona 675.
    Existing rule (supersport shown. I propose we change the same bullet in the MW Superbike section, as well.):
    2.2.3 Class Displacement and Configuration Limits A. Middleweight Supersport
    • Up to 640cc four cylinder
    • Up to 650cc pre-1984 four cylinder
    • Up to 750cc three cylinder, four-stroke 10
    • Up to 850cc two cylinder, four-stroke, three or more valves per cylinder
    • Up to 904cc two cylinder, four-stroke, two valves per cylinder, air cooled
    • Unlimited displacement pushrod, two cylinder, four-stroke, two valves per cylinder, air cooled
    Proposed Change:
    • Up to 640cc Pertinent section (4.4.1 bullet 'J'. 5.1.2 bullet 'A' sub-bullet ix)four cylinder
    • Up to 955cc two cylinder, four-stroke, three or more valves per cylinder
    USBA Rulebook (Pertinent sections below: 4.4.1 and 5.1.2):
    https://www.utahsba.com/wp-content/u...ule-Book-1.pdf
    4.4 Class Limits 4.4.1 Middleweight Superbike
    a. Up to 640cc four-cylinder, four-stroke, three or more valves per cylinder
    b. Up to 750cc three-cylinder, four-stroke, three or more valves per cylinder
    c. Up to 850cc two-cylinder, four-stroke, three or more valves per cylinder
    d. Unlimited displacement two- or three-cylinder, four-stroke, two valves per cylinder
    e. Up to 250cc one or two-cylinder, two-stroke, water cooled, unlimited origin.
    f. Up to 1050cc four-cylinder, four-stroke, two valves per cylinder
    g. Up to 510cc single-cylinder, two-stroke, water cooled h. Unlimited displacement two-stroke, air cooled
    i. Unlimited displacement single-cylinder
    j. Exception: Ducati 899 and 959 are permitted to race in this class
    And
    5.1.2 Class limits are set as follows:
    a. GTU (as applied to all GTU classes except Lightweight Superbike)
    i. Up to 430cc two- or more-cylinder, two-stroke, unlimited origin
    ii. Up to 550cc two- or more-cylinder, two-stroke, if frame is from a motorcycle manufactured for street use in North America
    iii. Up to 550cc single-cylinder, two-stroke, unlimited origin
    iv. Up to 675cc three-cylinder, four-stroke, liquid cooled
    v. Up to 640cc four-cylinder, four-stroke, liquid cooled
    vi. Up to 850cc two-cylinder, four-stroke four or more valves per cylinder, liquid cooled
    vii. Up to 900cc three- or more-cylinder, four-stroke, air cooled
    viii. Unlimited displacement air cooled two-cylinder, four-stroke two or three valves per cylinder
    ix. Unlimited displacement single-cylinder, four-stroke, unlimited origin
    x. Forced induction (e.g., turbo- or supercharging) is not allowed
    xi. Exception: Ducati 899 and 959 are permitted to race in this class
    Jim Søiland
    #93
    Blood Nickel Leathers
    Vortex
    Quote Originally Posted by Ducdreamin View Post
    + 1... it was starting to get pretty confusing out there, IMO.
    Bob - #46
    MRA President (2024-2025) - Vice President (2022-2023)
    "Racing makes heroin addiction seem like a vague wish for something salty." - Peter Egan
    Colorado Sportbike Club | 4 Horsemen Racing | R.I.P. 502
    Everything works out in the end. If it hasn't worked out, it isn't the end!
    1,257
    In order to hopefully avoid having one race with a LONG delay requiring a lap count cut for every remaining race:
    Existing Rule:
    7.1.I. When more than 50% of the race is complete and the red flag is displayed, MRA officials may consider the race complete. If determined complete, riders will be scored according to 7.1.J.
    Rewritten as:
    7.1.I. Excepting the 30-minute endurance races and RoR, no race shall be allowed to consume more than 30 minutes of the race day, with the 30-minute clock starting at the time the race starts (according to timing/scoring) and ending when the checkered flag is displayed. Any race delayed by red flag or otherwise may be restarted at any time prior to the 30-minute time period expiring and the checkered flag will be displayed to the leader at the next passing after the 30-minute clock has expired. In the event that the 30 minute clock expires prior to a race restart, the race will either be considered complete and scored according to 7.1.J, or declared canceled, at the discretion of the MRA officials. When more than 50% of the race is complete and the red flag is displayed, MRA officials may consider the race complete even if the 30-minute limit has not been reached. If determined complete, riders will be scored according to 7.1.J.
    Member Novice
    39
    Thunderbike. Allow 2 cylinder, 4 valve, liquid cooled bikes up to 1200cc’s. Thank you
    Aug 2005
    1,253
    Closed
