2009 CBR600rr parts
stock parts off of a 2009 CBR600rr I no longer have
![](http://i.imgur.com/O1JVRJc.jpg)
* rear wheel
* rear rotor
* rear sprocket
* cushdrive assembly
* Rear wheel axle, spacers, caliper bracket
* swingarm
* shock
* swingarm axle
* pillion peg hangers w/ footpegs
* subframe
* tail plastic
* seat pads (pax is torn a little on the corner)
* front fender
make an offer if there's something you can use
would trade for 03-05 R6 parts
almost forgot: I should have the stock rearsets somewhere, too.
need that subframe if still available.
mike- (9 seven oh, 3three3, zerofourseven2)
Do u have the gear shift linkage.....What I resally need is the vertical arm that connects everything together.......need it desperately if u have ill come get.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
