Results 1 to 25 of 74
Thread: 2015 Rulebook Suggestions
Threaded View
  1. #39
    5.2.2 Technical Requirements for Novice, Amateur, and Expert Competition Motorcycles
    Current:
    R. Transponders must be securely mounted on the front fork between the upper
    and lower triple clamps and must not interfere with lock to lock motion of
    the steering nor bind on any controls or wiring. Approval of any variances of
    mounting location lies with the VP of Rules and Tech.
    Proposed:
    R. An AMB Tran X 260, or current 260km/h equivelant, Transponder is required and must be securely mounted on the front fork between the upper and lower triple clamps and must not interfere with lock to lock motion of the steering nor bind on any controls or wiring. Approval of any variances of mounting location lies with the VP of Rules and Tech. Failure to have a transponder mounted to the motorcycle at the start of a race may result in
    forfeiture of points scored for that race.
