Need to get the garage cleaned out and I have a ton of parts for the 2007-2008 Kawasaki ZX-6R I need to sell. I am a former MRA member several can vouch for me still with the club Wyeth Jackson, Tony Baker, Rob Christman, Ben Fox, Ed Duenez etc. All parts are in Portland Oregon.
• Used Radiator - One edge/corner dinged but still works fine - $40
• Brake Master Reservoir - New - 1 Avail - $15
• OEM Brake Lever - Black - New - $10
• OEM Tank Shrouds - Auction Writing on the right side, left is clean - $20
• OEM Ram Air Tube - Used - $20
• OEM Cush Drive - New in the box - $30
• OEM Cush Drive - Nearly new w/a few sessions on it - $25
• 43 tooth Silver Vortex Sprocket, like new - $30
• Right Side Hand control setup - OEM Bar, throttle housing, kill switch (No Cables) - $40
• Right Side Hand control setup - OEM Bar, throttle housing, cables, kill switch - $50
• Left Side Hand control setup - OEM Bar, Headlight switch assembly - $30
• Lower Triple Clamp - Used but straight - $75
• OEM Left Rearset assembly - little rash on shifter - $50
• SBS Sinter Rear Pads - 1722-0043/687CS - 2 sets - new- $25 set
• OEM Rotor bolts - 7 New, 5 used - $10
• Spiegler Rear Stainless Brake Line - Blue - New in box - $40
• OEM Instrument Cluster (not sure on mileage) Needs a new back to the housing to mount. Cluster is good, I stole the housing off this set for one I damaged and never replaced it - $60
• Brake Speed Bleeders - Part SB7100S stainless Fit many makes http://speedbleeder.com/Motorcycle%20Sizes.htm - $10 each 6 available
• OEM Brake Pedal - End has some scratches - $15
• OEM Brake Pads - NEW - $40
• OEM Positive Battery Cable - $5
• OEM Body Work Mount - New - 11054-0657 - $10
• OEM Clutch levers - New - 2 avail - I believe they are Kawi - $10 each
• OEM Rear Brake setup (caliper, hose, master) - complete - $100
• OEM toolkit - $20
• OEM Fan - $10
• OEM Exhaust Servo - $10
• OEM Exhaust Gaskets - 3 avail - $10
• OEM Fairing Bracket - New -11054-0656 - $10
• OEM Fork Pinch Bolts - New - 92153-0854 - $5
• OEM Front Wheel Spacers - 3 sets - $5 each
• CRG Shorty RN-521 Lever - Grey - New- $50
• OEM Right Side engine cover - $10
• OEM Left Side engine cover - $30
• CRG Rebuild parts kit & 2 extra new shorty levers - New - $75
• Goodridge Double Banjo bolt - 03-1181 - $5 each
• OEM Rear Axle - $15 - New with adjuster blocks
• OEM Front Axle - $20 - New with female fork sleeve as well.
• OEM ECU Box - 0 miles on this unit - $100
• OEM Radiator Overflow - $10
• OEM Rear Shock, 0 miles - $50
• Woodcraft 3 piece shift lever, shorty - New in package -black - $40
• Strapless transport stand (ststands.com) for Kawi ZX-6R $100 & $150 One includes mounting plates (new) other you would need to buy them and ststands@ $45.
All prices are marked are reasonable and some are marked well below the going rate.
Prices do not include shipping.
I also have a full set of OEM Green bodywork including fender and windscreen with zero miles on them, including all OEM removed parts (rearsets, passenger rearsets, passenger seat, head light, tail light, blinkers, mirrors, kickstand, license plate brackets, radiator fan, exhaust heat shield, OEM Chain and Sprockets, horn, OEM Clipons, seat lock assembly, OEM Fork Internals, lots of bodywork bolts etc, everything removed for race prep) for an additional $900.
Email or call for more info
jmwatkins@dsl-only.net
503-830-0688
