I have found that using just the tips of my fingers on the Brake lever help with this problem...... you mention needing longer fingers, so I think you may have already tried this, but can you adjust your lever at the "perch", so that the lever is closer to your bar?Originally Posted by McLovin
and.... practice, practice, practice.... keep in mind that you don't need to be on the track to practice smoothing these motions out, and training your hand to do both things at once, you can practice this while sitting on the bike in the garage or in your pit.....
Not sure if any of this helps, but I thought I'd chime in.
~Brownie
