SOLD
Up for sale is a Yamaha YSR50 two stroke, 5-speed mini bike. This thing is a blast to ride. Perfect for roadrace training, cruising the local kart tracks, or racing with Rocky Mountain Mini Moto. Some people even register these things as "Under 50cc" bikes to ride on the street around the neighborhood. No title. Race bike runs great. Let me know if you have any questions. SOLD . Willing to work out trade for a dirt bike. Let me know what you got. Thanks!
Fresh Motor (piston, rings, wristpin, piston bearing, head gasket, base gasket, crank seal, intake gasket, spacer gaskets)
Fresh stock clutch (steel, frictions and springs)
2 spring fork kit (aftermarket springs and heavier fork oil)
Fresh fork seals and dust boots
Team Calamari lower fork brace
Team Calamari upper triple brace
Aluminum Clip-ons (standard replaceable bars)
Aluminum front wheel spacer (replaces speedo drive, seriously reduces drag on front wheel)
Rearset lifters (moves rearsets up and back)
Fresh Dunlop TT92's
Aftermarket rear sprocket and 420 chain
K&N Air filter
Mikuni 24MM Flat Slide Carb
1/4 Turn Side Pull Throttle
1/4 Turn Throttle Cable
Carbon fiber reeds
Oil block off plate
Aftermarket gas cap (1/4 turn quick release)
Steel braded brake lines
Cheetah R7 bodywork with tinted windscreen
Removal of kick starter (original parts are in the box for easily adding back)
Overflow bottle per Rocky Mountain Mini Moto rules
SOLD
Post up here or email caseydragos@hotmail.com
Thanks!
