To start with, I agree with Casey. Something is probably just not hooked up. Can you hear the fuel pump kick on when you first turn the key on?
If you want I can swing by and give you hand. And yes I do have the Service manual if you need it.
I doubt it is a kickstand, safety switch, as that would not let you turn the motor over at all.
