Results 1 to 13 of 13
Thread: Help with R6 / wont charge battery
    Littleton, Co
    1,659
    My R6 is having trouble charging the battery. Here is the history:
    Last race weekend bike wouldn't start. Battery was dead. Bump started and made about 2 laps until the tach turned off and then the bike died. Brought the bike in and found one lead on the rectifier was melted (lead was for one of the three white wires coming from stator). Also was showing check engine light with code 46. I swapped the stator and rectifier and the weekend finished with no issues.
    Last Sunday I went to the Chicane day and again had a dead battery. Bump start and made about 1 lap before bike shut off. Again, had check engine light and code 46. This time it was the negative lead at the rectifier that was melting.
    So, I have swapped stator and rectifier. Last night I tested the stator resistance per manual and it was good. Also tested the output of the rectifier and showed 14V at 5000 RPM (per manual). Continuity for stator and rectifier wires tested good also.
    Anyone have any ideas? I'm thinking maybe there is a short somewhere that is draining the battery. Could be the reason its dead before each session? I have a multimeter but just not sure what else to check. Should I swap wire harness? ECU? All help is greatly appreciated. Thanks in advance guys!!
    Case of beer (or whatever you drink) for the person with the correct answer 8)
    Member Novice
    Sep 2007
    colorado springs, CO
    31
    Have you tested the battery?
    Ken 702
    Littleton, Co
    1,659
    Yeah battery is around 13V when its fully charged and disconnected. It does drop a bit once i hook the positive and negative cables up. Any idea if that is normal?
    EDIT: If the battery was bad, wouldn't the bike still run after a bump start?
    I am having the EXACT same issues with one of my R6's... can't figure it out!!!!!! 8)
    Littleton, Co
    1,659
    Quote Originally Posted by Throttleroller277
    :cry:
    So the manual says to check the wire harness. Any idea what I am checking? Would I just test resistance with an Ohm meter?
    Yeah I guess so?...... At this point I'm thinking about getting a new harness......?
    On that note...you are running the stock harness that I gave you earlier this season, right?...if so that harness is virtually brand new, as it was only used for one season, then it was replaced with a kit harness.
    Ahhgggg!!!
    Littleton, Co
    1,659
    yeah thats the harness I have on it right now. been working fine for half the season. I might just throw back on the old one to try and eliminate some things. good luck with yours brownie, keep me posted if you find anything and i'll do the same.
    1,829
    just measure the continuity through the wires to check for shorts otherwise I'd suggest Marv Rosencrans at Rocky Mountain Kawasaki as he's a genius with electrical diagnosis
    Littleton, Co
    1,659
    Quote Originally Posted by Jon
    Thanks Jon, I have a digital multimeter now so I will test that tonight. Thanks also for the referral.
    1,829
    I am not by the way sponsored in any fashion by RMK but I was a certified Yamaha Technician from 93-95 since then I've found craftier ways to earn my keep. I know Marv can figure out things I couldn't and he's for sure one of the best. Best of luck as electrical gremlins can make you pull your hair out....at least that's what happened to me :?
    Jul 2009
    utah
    221
    r6
    good luck
    Jan 2006
    Thornton
    216
    when it runs, does your regulator make any unusual heat?
    Justin Meyer
    #74
    Littleton, Co
    1,659
    the first one was really hot when we pulled it off. of course it had a severely melted connection. when i put the new one on, it never got really hot. just like normal temp you would expect.
    any ideas?
  1. WTB: Battery
    By Tucky in forum Wanted!
    Last Post: August 6th, 2013, 07:42 PM
  2. GSXR Wont start (different from bellow)
    By James87 in forum Rules & Tech
    Last Post: May 30th, 2012, 06:57 AM
  3. Lightweight Battery
    By Clarkie in forum General Discussion
    Last Post: January 23rd, 2011, 12:02 AM
  4. Interstate TX-4L-BS Battery
    By bluedevil in forum Parts For Sale
    Last Post: June 8th, 2009, 06:53 AM
  5. CBR F3 wont start -help!
    By Mforza in forum Wanted!
    Last Post: January 18th, 2009, 11:26 PM
