Thread: 2nd air valve?
    Jan 2010
    52
    2nd air valve?
    so i noticed today that the 2nd air valve was hanging off my bike (07 gsxr 600) by the electrical plug only. None of the hoses are hooked up any more so do i still need this thing since its still got the electrical wires plugged into it? any help on what to do with this damn thing would be appreciated.
    http://www.copowersports.com/fiche_s...006&fveh=11387
    #4 in that link is what im talking about.
    Thank you.
    The pair valve was disabled (block of plates our some other way) but the solenoid wasnt bypassed. You can either leave it or disable it
    647
    The Secondary Air Injection Reaction Solenoid Valve (second AIR valve) resistance is monitored by the ECM, and will set codes in the ECM as well as sometimes effect engine operating perameters, if these codes set. If the reed valves, and or supply hoses have been blocked off, you can just leave it plugged in to eliminate any hassle. You would have to recalibrate the ECM or use a Kit ECM in most cases to be disable it's command or monitor in the ECM to be able to remove the wiring or solenoid valve. See you at the track soon!
    Speedin' Motorsports
    Or you can just "put" a resistor in place :wink:
  1. Valve adjustment
    By İurbow in forum New Racer Q & A
    Last Post: June 1st, 2013, 08:46 PM
  2. Suspension Re-valve and Re-spring specials
    By LMsports in forum Supporting Vendor Ads
    Last Post: March 18th, 2010, 06:23 PM
  3. Oil Pressure Relief Valve
    By jbird in forum Wanted!
    Last Post: April 10th, 2009, 05:03 PM
  4. valve jobs
    By benfoxmra95 in forum Supporting Vendor Ads
    Last Post: February 18th, 2009, 07:58 AM
  5. secondary throttle valve actuator
    By glenngsxr in forum Wanted!
    Last Post: August 26th, 2005, 04:42 PM
