Results 1 to 3 of 3
Thread: Wtb: Stock Brake master cylinder & clutch perch with lev
    Apr 2007
    39
    Looking for an inexpensive stock bmc and cable clutch perch with levers from any fairly modern sportbike.
    This just to get the 250 up & running, so pretty much any OEM bmc should be sufficient. Hopefully some stock parts are laying around in a garage somewhere.
    The only caveat, the clutch perch needs a large cable adjuster wheel for easy adjustments, like the one on this zx6r:
    http://zx6r.com/photos/watermark.php?file=4934&size=1
    Edit: noob mistake, I thought I was in the wanted forum. Can a mod please move this thread?
    and by 250 he means a mid 90s TZ250. most universal fit clutch lever and perches fit
    Apr 2007
    39
    Quote Originally Posted by marty
    Thanks Marty!
    Eventually I'm gonna get the brembo 19 RCS BMC, but that's down low on the priority list.
  1. master cylinder upgrade? good deal incl free brake lines
    By slo lee in forum General Discussion
    Last Post: May 17th, 2013, 05:03 PM
  2. Front brake master cylinder
    By widmannj in forum Wanted!
    Last Post: July 1st, 2011, 12:10 PM
  3. Brembo Clutch Master Cylinder
    By jbird in forum Parts For Sale
    Last Post: July 2nd, 2009, 06:48 AM
  4. clutch perch for 03' zx6r
    By in forum Wanted!
    Last Post: February 3rd, 2009, 09:53 AM
  5. Brembo Radial Master Cylinder Front Brake
    By turtle evans in forum Parts For Sale
    Last Post: November 9th, 2008, 11:16 AM
