Results 1 to 21 of 21
Thread: GSXR Wont start (different from bellow)
    Junior Member Novice
    May 2012
    Colorado Springs
    17
    I purchased a 98 GSXR 600 that was full race prep yesterday. I got the bike home and took it around the block, other than not wanting to idle it ran fine and had great power throughout the rpm range.
    The previous owner added an LED tail and a small headlamp to make it street legal.
    Well today I pulled the headlamp and LED tails off, then pulled the tail section to give it a few coats of rattle can goodness.
    At that point I tried to start the bike and and it turns over fine but doesn't actually start. I charged the battery up and its still a no go :?
    I went over all wires and grounds with a fine tooth comb, as this has to be an electrical issue. It doesn't seem to be getting spark, but I haven't confirmed this yet.
    Thanks in advance for any help as any suggestions would be greatly appreciated.
    Senior Member Expert
    May 2005
    2,416
    Start with the simple stuff -
    Kill switch?
    Kickstand Jumper?
    then confirm spark by pulling a plug (or two)
    MRA Expert #69
    Sponsored by: Chicane Instruction
    STM Suspension, Speedin' Motorsports
    Northern Colorado Euro Motorcycles
    Boulder Motorsports, Sol Performance Pirelli
    Angry Marmot Motorsports
    Sarah, Aaron and David
    May 2012
    Colorado Springs
    17
    rybo, Thanks for the fast response.
    I checked the kickstand jumper and it is in working order.
    Kill switch is also operational. also, whats the best way to actually test the switch?
    I pulled all four plug caps (1 at a time) and used a spare plug to test, and all had very good spark.
    A side note: 3 of the 4 plug boots shocked the daylights out of me as I inserted the spare plug. The key was off and I had not tried to start in at least 20 minutes. Is this normal?
    Thanks again
  4. #4
    May 2012
    Colorado Springs
    17
    Update: After letting the bike sit for awhile, I tried again and got it to start.
    However, the bike just didn't sound right. Also, I had to keep the bike at about 5k RPM's to keep it running. Once I let off the throttle it died immediately. On a hunch I decided to check the primaries for heat. 3 were scorching hot and one was stone cold (cylinder #2 from L to R as sitting on the bike).
    I confirmed this cylinder to get spark earlier, so I'm at a loss.
    Ill recheck for spark again in a bit. In the mean time if you have any suggestions I'd appreciate it.
    Thank you kindly
  5. #5
    Mohammer Time! Expert
    Aug 2005
    1,253
    Recheck for spark.
    Check your plugs to see if they are fouled. New plugs couldnt hurt.
    Check compression.
    Leak down test.
  6. #6
    Oct 2005
    1,199
    Air, spark, fuel. If one is missing our low no vroom vroom :wink:
  7. #7
    May 2005
    2,416
    How about clogged jets in the #2 carb?
    MRA Expert #69
  8. #8
    May 2012
    Colorado Springs
    17
    Scott, I think that is the issue.
    I re-confirmed spark in the #2 cylinder and it was very strong. I also went ahead and pulled all 4 plugs to check there condition.. Well all 4 were black and sooty. Also, They smelled like really old fuel, a very sweet kind of smell.
    So I think its time to get into the carbs.
    TRK, Thanks for recommending the compression test I never thought to do that. I Will be checking that soon. How is the leakdown test performed?
  9. #9
    May 2005
    2,416
    Cleaning up the carbs on any bike that's been sitting for a while is almost mandatory.
    Leakdown test is a bit like a compression test but holds at compression to see if there are any slow leaks (like a valve not seating properly)
    MRA Expert #69
  10. #10
    Senior Member Amateur
    Apr 2009
    174
    Coming from dirtbikes, sounds like clogged pilot jets. And definitely new gas before you try again.
  11. #11
    Senior Member Expert marty's Avatar
    Dec 2006
    arvada, co
    596
    Quote Originally Posted by James87
    Sarcastic sweet or actual sweet? If actual sweet, does any of the oil look milky? If sarcastic sweet, I concur , old gas will make your nose hairs curl :lol:
    RS 125
    TZ 250
    #738
  12. #12
    May 2012
    Colorado Springs
    17
    Well I pulled the carbs and had a peek inside. All jets, in all four carb bodies were completely clogged. So I stripped them down one by one and cleaned them using compressed air. I did not remove the plunger assembly, but verified that they do move freely.
    I also removed the fuel sending unit from the tank to check fuel filter condition, And it was nice and clean. then I went ahead and cleaned out the airbox and blew out the air filter.
    At this point I put everything back together and she fired up nicely.
    However, now my idle is alllllllllll over the place. Initially, it stayed around 3k rPM and jumped up and down agood 1k - 2k. after a minute or two it would drop and almost die. But as soon as I touch the throttle it starts screaming again.
    jgixxer1, I wish I would have seen your post earlier as I reused the old fuel ops: what was I thinking!?
    marty, It actually had a sweet smell to it, A pungent sweet smell. I haven't drained any oil as of yet, but looking into the sight hole, Its a dark brownish, black color. Note to self: Change oil
  13. #13
    May 2012
    Colorado Springs
    17
    I did notice one thing I have to ask about. The 2 "inside" carbs had a richer main jet than the outer ones. Is this normal?
    Sorry this has gone on as long as it has, but I really do appreciate all of the input you guys are giving. Thank you kindly.
  14. #14
    Dec 2006
    arvada, co
    596
    The joys of an older bike! :lol: I'm just in the middle of splitting cases because my 125 was burning water. A leak down and compression tester for older bikes will be well used tools. Snap on, mac, etc all make nice ones but a nice OTC or the like will work great for as little as you will use it. I can't say for sure but Tool Zone on I25 always has a nice assortment of well priced automotive tools.
    Another must for older bikes is a service manual. Haynes and Clymer are nice but a factory one is the jam!
    RS 125
    TZ 250
    #738
  15. #15
    May 2012
    Colorado Springs
    17
    lol you said it marty, But I do enjoy getting my hands dirty :lol:
    I have a compression tester and a shop manual for the bike, so I have some figures for you and there not pretty.
    CYL #1: 125 PSI
    CYL #2: 120 PSI
    CYL #3: 115 PSI
    CYL #4: 120 PSI
    According to the manual, Standard is 156 - 213 PSI with no more of a difference than 28 PSI.
    I suppose a rebuild is in order. Any of you shop guys out there feel free to chime in with a quote if at all possible.
    marty, would that be an Aprilia RS 125? Ive always wanted a 2 smoker to throw down on.
  16. #16
    Dec 2006
    arvada, co
    596
    Honda RS 125. I wish I had the cash for a RSW 125 Ape
    Give Bart a call over at Faster, he could get you a quote for a rebuild. If you have the manual and don't mind getting oily you could freshen it up yourself
    RS 125
    TZ 250
    #738
  17. #17
    Oct 2005
    1,199
    Was the motor warm or cold when you did the compression test? It should be warm and it makes a pretty big difference
    Also, balance the carbs :wink:
  18. #18
    May 2012
    Colorado Springs
    17
    Clarkie, I had warmed the engine to around 160 - 170 degrees when the test was done. Ya, I have instructions to put together a cheap carb balancer. I guess I'll putting those to use lol.
    marty, Thats still a nice machine. Ill be calling Bart in the morning for a quote. I could do it myself, but all my benches are riddled with FZ 750 parts. The fun never ends. :lol:
  19. #19
    Oct 2005
    1,199
    Do a leakdown test and it will tell you if it is valves or rings, my race bikes were always 240-260 psi but I ran higher compression than most could get away 8)
  20. #20
    Jul 2010
    Silverthorne, CO
    647
    If the bike has been sitting a while (sticky/glazed rings), and you cranked it with the throttle plates closed, you would get numbers like those anyway. A general rule of thumb is the cylinders should all be within 10%. It takes a bit more to condem a specific cylinder as having a serious sealing problem. You may want to get things squared away with basic engine management fuel/air to see how well it comes around. You really can't use compression tests as accurate data, they leave way to many valuable pieces of information out. Absolute barometric pressure in Denver was 24.45"Hg a few days ago. Compare that to 29.93"Hg at sea level and you are already at 80% of the specification in your manual just for alltitude compensation <124-170psi>. Good luck!
    Dennis Stowers MRA #151
    2021-2023 MRA BoD Rider Representative - Rulebook
    Absolute Moto-Michelin
  21. #21
    May 2012
    Colorado Springs
    17
    Fastt Racing, Thanks for that very informative post! I had no idea altitude had adversely effected the compression test. I suppose it does make sense when you think about it though.
    I know the bike has the ability run nicely so I will focus my attention on the normal maintenance stuff and also go through the carbs and fuel system to get everything in good working order.
    Thanks again everyone!
Similar Threads
  1. GSXR won't start
    By CaneZach in forum Rules & Tech
    Last Post: April 30th, 2012, 10:13 AM
  2. Help with R6 / wont charge battery
    By dragos13 in forum General Discussion
    Last Post: August 19th, 2009, 12:40 PM
  3. PR- Start Something- Volunteer Here
    By Wild Cheetah 612 in forum General Discussion
    Last Post: July 14th, 2009, 11:02 AM
  4. CBR F3 wont start -help!
    By Mforza in forum Wanted!
    Last Post: January 18th, 2009, 10:26 PM
  5. Bike Won't Start
    By -TK- in forum General Discussion
    Last Post: March 16th, 2008, 12:30 PM
