Results 1 to 24 of 24
Thread: 2003 Honda CRF450 Supermoto - SOLD
    2003 Honda CRF450 purchased new (from our very own Tracy Schram at Sun Honda)
    Aftermarket small offset triples, new bars, suspension completely redone (multiple times actually to get it right), ported head with 1+mm bigger valves, oversized rotors, 17" wheels with Pirelli Supercorsa race tires, XT lap timer mounted, and a bunch of other stuff I am forgetting.
    Left front fork seal is weaping so it both should be replaced with fresh oil, but other than that, she is ready to go. Runs great, really reliable, as fast as the YZ450s with more torque, and surprisingly fun at all of the MRA tracks and will give big bikes a good run in the tight stuff.
    $3000 or best offer.
    Interesting trades considered.
    Email dave@motosix.com
    174
    What gearing and how much time on the head work? Have a friend in the market. I sent him this link.
    Quote Originally Posted by jgixxer1
    Gearing worked at IMI and at Pueblo. No idea what the rear is but I could find out. The front is (I think) a 15, or whatever the biggest one you can run without cutting the cases. Bartman could tell us which one that is...
    The 2006+ (I believe?) heads used the larger valves but are a direct bolt on. So instead of redoing the original head, I bought an entire new head with a "Level 1" port. It is a mild prot that really just opens it up a bit and unshrouded things. It was a noticeable difference over the original 2003 head however. The headwork was done in 2007(ish), and has a bunch of IMI time on it and (1) MRA race weekend at Pueblo.
    There is no slipper clutch, but I am used to riding twins so I don't rev the shit out of things. This is the opposite of a YZ450; it falls on its face up high but pulls like mad down low, so short shifting it actually is faster than rev'ing the piss out of it and I never worried about top end time due to that. Of course, YMMV as these things have popped in the past, but mine (and Barts and everyone else I know who doesn;t build the snot out of them) have had no problems.
    Oh, and so the dates dont confuse you:
    I have not ridden this bike since Clarkie hit the wall. We used to beat the hell out of each other at IMI on the Sumo's, and it wasn't the same afterwards. (for multiple reasons )So, it has not had years worth of wear and tear since the work.
    The bike is located right outside IMI (literally, right outside the track) so if anyone wants to try it out I can clean her up and you can give her a go.
    My YZ450F SM was fully built (stock bore) with high comp piston, cams, headwork etc and I was always suprised how well your CRF got out of corners when we used to play at IMI 8)
    For the record, the bottom end of my 450 is stock. Good shape, but stock.
    Like Clarkie says, my bike got off the corners surprisingly well. His made power like a roadracer (and good power at that), but I was always pleasantly surprised by how little work I had to do to mine to make it a fun bike.
    We had dyno curves done of both bikes on the same day. I won't say any numbers, but the CRF was down 3 to 4 ponies up top (as I remember? Is that right Aaron?), but didn't have to rev very hard to make a bit more torque down low. All of the bikes (built or not) were relatively close to each other in curves once the jetting was right. Clarkie's was faster at IMI, but that was mostly rider.
    Here is a graph I found of your 2004 CRF450 vs my 2006 YZ450F, I ended up getting a few more hp on top above 9,000rpm due to a modified full system Leo Vince exhaust, degreeing the hotcam for top end and some good race gas, but the bottom power never came up. The Honda's always made great horsepower and torque on the bottom end and this shows on the dyno below 8,000 and more importantly at a track like IMI.
    Damn, thats cool. Glad you still have that stuff!
    Extra info:
    Rear axle is large enough to fit a Strapless Stand bar through. I used an R6 setup on her in the trailer and it never moved an inch from here to Miller and back.
    Stock header is Ti (for those of you who didn't know). The aftermarket exhausts are cool, but the stockers flow pretty darn well for where this bike makes its power, so no need to drop a $G down on new exhaust for it.
    Also, she is jetted for altitude (for those of you emailing from out of state). It will be lean at sea level if it goes there, although it is safely fat and doesn't run hot.
    Apr 2008
    EARF
    666
    If this is still for sale in June I will pick it up.... I'd like to take a look soon
    Lifetime novice.... #969
    l ______
    /l ,[____],
    l---L -[]lllllll[]-
    ()_) ()_)----)_)
    Quote Originally Posted by NossLou
    Come take a look! But, she will be gone by June. 8)
    Apr 2008
    EARF
    666
    I see that she sold...Glad you got rid of it before I got greedy
    l ______
    /l ,[____],
    l---L -[]lllllll[]-
    ()_) ()_)----)_)
    No -- the 125 was sold. The 450 is still available!
    Apr 2008
    EARF
    666
    uh oh all right game still on I'm going to try not to force it, but we will see....
    l ______
    /l ,[____],
    l---L -[]lllllll[]-
    ()_) ()_)----)_)
    Sep 2006
    Littleton, CO
    1,228
    *hijack* I have your old sumo Clarkie, just need to get off this weekend shift so I can race and put it to the test....
    sorry Dave, GLWS!
    450 is cleaned up and now in Denver so come check it out (and bring it home with you!)
    $2750
    COME GET THIS THING OUT OF MY GARAGE!
    email sent
    Quote Originally Posted by marty
    email sent
    If I have to tell you to stop sending me pics of yourself in Speedos one more time I swear to sweet baby Jesus I will grid you on the front row of RORO on your RS125.
    (Whole new meaning to "Pole Position"?)
    Quote Originally Posted by dave.gallant
    email sent
    8 pound 6 ounce newborn infant Jesus? :lol:
    No, I meant the really tasty sweet baby Jesus:
    Did you tell CWeed that you're selling this... I'm sure he'd love to have a spare sumo just in case...
    Nope.
    Seaweed. Paging Mr C. Weed. Please pick up the closest courtesy telephone and dial 1 for your operator.
    SOLD!
  1. 2003 yz450f supermoto - Sold
    By jgixxer1 in forum Bikes For Sale
    Last Post: October 11th, 2013, 04:52 AM
  2. 2006 Honda CRF450 Supermoto / Dirt For Sale!
    By orgsxrracer in forum Bikes For Sale
    Last Post: October 11th, 2011, 09:28 PM
  3. Replies: 5
    Last Post: October 15th, 2010, 06:24 PM
  4. 2003 Honda CBR 600RR $4000 more pics !! SOLD !!
    By DowntoEarthDental in forum Bikes For Sale
    Last Post: January 23rd, 2010, 05:18 PM
  5. CRF450 supermoto parts.
    By Duaner in forum Wanted!
    Last Post: November 23rd, 2005, 07:34 PM
