Are there any tricks to fitting Corsa bodywork? It seems little lines up on the right side and belly pan and I cannot figure out how to attach the front part of the tail section.
thanks,
thanks,
I used basic hardware to mount where pop rivets hold on stock bodywork. I could email you a pic if you like. I spent a good bit of time with the Dremel to get my upper and lower right. I didn't pre fit the upper to the lower. I started with the upper and worked down. I can't imagine the Corsa is much different than the HB. I also used stock fasteners, except at the tail and upper/lower. I picked up the Dzuz at my VW dealer. Don't forget to remove the short frame plastic on the upper as well.
I forgot to mention, install the tank trim when fitting the tail. I didn't and it's way off on the left side. Too late now ](*,)
