Thread: 2008 Kawasaki Ninja 250 Race bike. Production 250 legal!
    Aurora, CO
    520
    The bike has a clean Colorado title and will come with the street plastics (green), but they are all damaged and/or rashed. The lights, mirrors, ignition switch, fuel cap and pillion have been sold off to help finance the build. I sold the stock tank and put a slightly dented (repaired) tank on it for racing. The kickstand bracket has been cut off for clearance issues. Wiring harness is complete and intact. I have raced/tracked this bike since last October. I changed oil every 2-3 races/trackdays.
    • Sharkskins bodywork w/ Puig wind screen, very nice stuff with slight cut out for clipon clearance. The paint is rattle can, so not the highest quality but I don’t dump a ton of $ into paint for race bikes.
    • Completely safety wired to pass MRA tech + some personal preferences
    • Ignition key eliminated and weather proof toggle switch installed
    • Set up for a hardwire transponder that can be turned on and off with bright light rocker switch. It is also drilled and can be pinned to prevent accidentally turning it off.
    • I installed LED idiot lights in top triple for neutral (green), transponder power (blue), oil pressure (red) and water temp (yellow).
    • I made a couple of brackets to hold a Vapor computer but I use it for my Droid as a lap timer. This entailed me cutting off the ignition switch mount on the triple.
    • Woodcraft clip ons with the 2 in. risers specifically for the ninjette
    • Hong Kong (CRG) knockoff adjustable brake and clutch levers. (Spare clutch lever)
    • Sportisi adjustable rearsets set up GP shift (cut out counter sprocket cover with an unaltered spare).
    • Brake lines changed to braided steel front and rear.
    • Front brake pads are new and were installed 10/15/2011 and the brake fluid changed and bled.
    • Coolant was also changed and antifreeze added for winter.
    • Pingle dogbones to raise rear 1 ½”.
    • Newish (1 race an 2 track days) 520 standard (non oring) DID racing chain for less rolling resistance and 3 aluminum rear sprockets 45T(stock and what I use @ HPR), 47T and 49T (IMI), along with a spare carrier so gearing change take 10 min.
    • The front forks were service with fresh oil (15wt., stock is 7.5wt.) mid season and I added spacers to increase preload 10mm. This and raising the rear ride height made a huge improvement in handling and front tire wear. I am ~210# and race sag is real close with the stock springs.
    • The carbs have been jetted and shimmed.
    • The exhaust is a full 2 into 2 Totsubo GP style that is undoubtedly the loudest exhaust you can put on a 250. And I mean really really loud! I did a side by side dyno comparison of the Totsubo and the AreaP short CF system by running one on the dyno and then pulling the exhaust and bolting the other up with out removing the bike and then ran that one. The Totsubo put out almost 1 ½ hp more in the sweet spot of the curve so that is what stayed on the bike. But be warned, it is fraking loud!
    • I have run Bridgestone BT-003 RS 140 rear tires and BT-016 110’s on the front all year and have been extremely happy with the performance for the price. The current rear is nearing the end of it’s useful life, the front is still in good shape.
    • I have some spares for the bike in addition to what has been previously mentioned
    I am asking $3800
    Ankle Biter Racing #99
    Sol Performance--Scorpion -- Vortex Racing
    MaxFund No-Kill Animal Shelter and Adoption Center
    Aurora, CO
    520
    bumpence
    Jul 2008
    Fort Collins
    66
    want to trade for an r6??
    Aurora, CO
    520
    Sorry, I already have the new ride lined up.
  1. 2008 Kawasaki Ninja 250 Racebike - SOLD
    By willionaire in forum Bikes For Sale
    Last Post: October 23rd, 2013, 09:33 AM
  2. 2007 Kawasaki Ninja 650R street bike for sale
    By Bee833 in forum Bikes For Sale
    Last Post: August 4th, 2013, 07:17 PM
  3. 2008 Ninja 250 race/track bike $3500*SOLD Pending Funds*
    By Bueller999 in forum Bikes For Sale
    Last Post: February 4th, 2012, 05:43 PM
  4. 2009 Kawasaki Ninja 250 Street Bike - Under Contract
    By Spiderman in forum Bikes For Sale
    Last Post: April 6th, 2011, 11:55 AM
  5. Replies: 3
    Last Post: December 10th, 2010, 09:16 AM
