Hi,
So I have 2 separate questions.
On an 03 R6 that is having high temp issues, what radiator cap should I be running? I have a 1.1 but think it has either gone bad and isn't sealing due to old rubber or old spring thus boiling out to overflow too often.
second question is, during a couple tip overs in the paddock, my right rear stand spool screw broke right at the edge of the swing arm. (see attached pic) I have an idea on how to get it out but before I go off half cocked, wanted to see if there are any racing tips to this. I don't want to drill it out to a bigger size, re-tap and then have to find a bigger bolt for the spool and then have to widen the sleeve in the spool for the bigger bolt to fit so.... ideas?
