Results 1 to 8 of 8
Thread: Ducati 848.... anything special required?
    Colorado
    395
    Are case covers mandatory for this bike, uses a wet clutch. I wasn't aware of anything, but want to be sure before Pueblo. Anything in particular??
    Luke, Semi-Expert #199
    2010 Ducati 848, 2005 GSXR1000
    STM Suspension, Sol Performance
    Montana
    429
    I believe you need an aluminum water pump or cover...speedymoto makes some really nice ones! Someone can correct me if that changed from the 999 to the 848 style bikes!
    MRA #406
    406 Racing
    Michelin
    Speedin Motorsports
    RockyMtnPhotos
    Custom Collision Repair
    420science.com
    nothing is required but the waterpump cover is a good mod.
    I don't think the stock 848 comes with a steering damper - you'll need to add one of those.
    Colorado
    395
    got that covered, just heard 10 different things about case covers, didn't want to be caught out when I get to pueblo, that's all
    Quote Originally Posted by random hero
    All the normal stuff needs to be done of course but there is nothing weird on the 848s.
    Colorado
    395
    Couple more questions.
    Can I use RVT, or silicone on these 4 allen heads on the bottom of the drain pan. They're very low profile, not sure if I can drill them for wire.
    Also, can I RVT the water pump drain bolt... or does it have to be drilled? Again, another bolt that looks like it's going to be a PITA.
    Last, do the rear caliper bolts need to be drilled.... the setup is odd, and looks like it'll require me to disassemble the entire rear wheel/brake setup to get to these bolts...... worst case will you let that one slide for Pueblo ???
    Those are to short to drill for sure, I would get standard allen heads and drill them. Silly cone will do for the weekend and yes drill the water drain. We can look at the rear when you get there and will tell what to do.
  1. Why you are required to have a fire extinguisher-
    By JimWilson29 in forum General Discussion
    Last Post: June 20th, 2012, 08:40 PM
  2. New Years Special
    By Faster Motosports in forum Supporting Vendor Ads
    Last Post: January 3rd, 2007, 02:55 PM
