Results 1 to 9 of 9
Thread: brake pad pins
    113
    brake pad pins
    Do brake pad pins need to be safety wired? Looking at the rulebook it doesn't look like it.
    if it doesn't, you still may want to just for your own safety. they can wiggle out :shock:
    Absolutely wire your brake pad pins. I know of guys who have gone off at triple digit speeds because a pad falls out. Last year we had someone crash into 13 due to something like this.
    Don't worry so much about the specific rules as you do for your safety on this one!
    This may be a dumb question but what keeps the pin from falling out on a street / non-safety wired bike? I've got mine wired but can't think of what keeps 'em in without the wiring.
    Jamie,
    There are usually quick release pins on them or they screw in.
    Usually not a problem, but a good thing to take care of for a full time race bike.
    One of the stresses that the racebike sees that the streetbike does not is that we remove and replace wheels at a far greater frequency offering the opportunity for the pins to get dislodged.
    In the words of Scer - Wire on wirers!
    Jim 'smooth' Brewer
    One strong suggestion - use wire in addition to the stock fasteners, not instead of them.
    For example, if you have a pad retaining pin (#2) with pin clips (#1) holding it
    *don't* use wire instead of the #1 pin clips, use the pin clips and use wire to close the end of them. Reason being is that safety wire is quite prone to breaking & falling out whereas the pin clip is much more resilient.
    Here's a picture of a really good way of wiring the pin clip ..
    Most failures I've been aware of have been from people ditching the pin clips and just using wire.
    Apr 2008
    EARF
    666
    jim... wish i had cool pins like that!
    Lifetime novice.... #969
    l ______
    /l ,[____],
    l---L -[]lllllll[]-
    ()_) ()_)----)_)
    Sucks!!!!! ops: 8)
    Quote Originally Posted by Jim 'smooth' Brewer
    Jim even uses Mud as a third safety measure!! 8)
  1. pins for the pit bull trailer restraint system.
    By chris nami in forum Wanted!
    Last Post: June 28th, 2010, 11:16 AM
  2. Pitbull Ducati rear stand pins
    By Dodd in forum Parts For Sale
    Last Post: June 6th, 2010, 03:14 PM
  3. Replies: 6
    Last Post: April 8th, 2010, 04:22 PM
  4. Brake pad question
    By GNGSXR in forum General Discussion
    Last Post: February 13th, 2009, 10:40 PM
  5. OEM 06/07 R6 or 04-06 R1 brake lever
    By bluedevil in forum Wanted!
    Last Post: June 12th, 2007, 08:01 AM
