Results 1 to 5 of 5
Thread: R6 Parts, Warmers, Stands, Quickshifter
    481
    R6 seat 2007- new, $20
    R6 Wheels 06-11- $100 each
    1 Front, straight, no rotors
    1 Rear, straight- rotor, 520 sprocket and cush included
    1 Rear, straight, no rotor, but 520 sprocket and cush included
    R6 Pistal lightweight, high compression pistons, stock bore 06-11- $400, I was told these were a matched set from a Yamaha supported WSS team, and everything about them leads me to believe it’s true. Two of them are used very slightly (for dyno runs only is what I was told), and the other two are new. I thought I had these installed in my motor, but their presence on my shelf indicates otherwise. These would be a great alternative to a high commitment big bore motor. Pins are included. These retail, if you can get them, for $1200.
    R0045Q-10 Gapless Spark Plugs- these are the best money can buy, normally $70 per plug, $150 for set of 4
    Triple tree front stand- $75
    Aluminum rear stand- only weighs 6lbs!, so much better than a ridiculously heavy pit bull, $75
    Tire Bakers Tire Warmers- standard single temp, well used but work great $100
    XT Ultra Lap Timer $75
    Fork clamps- I have a 50mm and 52mm $20 each
    Traxxion Dynamics fork spring compressor $20
    Cardona quickshifter- push style, new never used $150
    I'm interested in your tire warmers. Can you call me @406-208-2388
    481
    I have someone interested in the stands and warmers, but I'll let you know if it falls through.
    Sep 2010
    6
    Interested in the lap timer if it's still available...
    Mar 2007
    if above poster doesn't follow through, pm sent about lap timer. thanks,
    mike-
  1. Going to GP Shift - need a new quickshifter?
    By spideyrdr in forum Rules & Tech
    Last Post: January 5th, 2013, 03:10 PM
  2. Ramps, stands and warmers - UPDATED
    By jamesfromkent in forum Parts For Sale
    Last Post: June 8th, 2012, 09:36 AM
  3. Replies: 6
    Last Post: May 19th, 2011, 04:16 PM
  4. Wanted - Tire Warmers and Bike Stands
    By snowryderclark in forum Wanted!
    Last Post: October 26th, 2009, 11:08 AM
  5. DynoJet Quickshifter
    By clowe in forum Parts For Sale
    Last Post: June 19th, 2009, 01:20 PM
