Results 1 to 8 of 8
Thread: GP shift opinion on a 2008 R6
    Oct 2010
    14
    Hello all, I just went from regular shift to GP shift. The problem Iam having is finding the shift lever with my boot. (new Boots may be problem) It feels like I have to put alot of effort in to move the lever from the top of my boot (shifting down ) to shifting up with the lever on the bottom of my boot. Is the position of the lever set different than a regular shift se up? Thank you Eric. Pics would be great or any advice.
    AAR624
    Las Vegas
    86
    I'm certainly no expert, but give it some time and practice. It will become second nature before you even realize it
    Lisa (Kary) Clark
    Former MRA #191 and #911 ("I'll be back!!")
    2009 R-6
    2003 SV-650
    2009 CRF-250X
    You can adjust the lever where ever you want. If you just swapped your shift shaft around and left the lever in the same place, you might want to play around with adjusting it. Having a difficult time grabbing your shifts will cause issues on the track.
    Oct 2008
    273
    What Casey said.. The lever doesn't have to move at all so shifting shouldn't be any harder than it was previously. The only tricky part is remembering down is up and up is down the first couple times you ride. Once it becomes subconscious you will see the benefit.
    Pete Tabor
    MRA #599
    Fun Center Cycles
    Sol Performance
    Speedin' Motorsports
    Along with what Casey and Pete said.....
    The effort that it takes, and the distance that it takes for your foot to move the lever up or down, should be relatively equal. I would try to shoot for that as a starting point.
    obviously.... have your race boots on when "feeling" it out, and move around on the bike in all positions; tucked in, hanging off both sides of the bike, etc....
    And maybe to prevent shifting in the wrong direction, you can do something like put a small piece of tape on your tach that says GP shift, as a reminder. After a full day it will become second nature...
    I have a couple pics of an 06 if this helps... at least shows the position of the shift arm and pedal....
    The above photos depend on the Rear Sets you have though. I use Woodcraft and Graves, and on both of them the shifter is mounted to the foot peg.
    Oct 2010
    14
    Thanks
    Thank you all for your help, I apreciate it. It is now adjusted and feels alot better
    AAR624
  1. Shift rod
    By Dodd in forum Wanted!
    Last Post: March 15th, 2013, 04:38 PM
  2. GP shift for 99-02 R6
    By chupale in forum Wanted!
    Last Post: April 11th, 2008, 06:15 AM
  3. Replies: 8
    Last Post: March 24th, 2006, 12:13 PM
  4. CDR opinion
    By Lurch in forum General Discussion
    Last Post: April 24th, 2005, 08:43 AM
