Thread: What the cuss is wrong with my bike?
    Castle Rock, CO
    304
    Ok all knowing MRA forum, I need some help. I started up the bike tonight and let it warm up so I could drain the antifreeze and flush with water and it puffed some blue smoke, not on startup but when warm it did it when I let off the throttle or when I revved it quickly.
    Never did this last season at all, only things I have done around the motor are change coolant, clean out the airbox, reconnect the battery, tighten throttle cable, change the oil/filter with a different brand, and re-seal the alternator cover with a new gasket.
    Is there any way the change in oil or filter could cause this? What about the seal of the alternator? (I used a small amount of RTV where the wires exit but was careful not to put too much that would get inside the case).
    Bike has never misbehaved, should I run it Saturday or park it until I can take it in?
    #91 Triumph 675
    Thanks to: Motowheels, Woodcraft, Cogent Dynamics, Toyota, and Nikkie
    I assume it's been sitting all winter? The valve guide seals are probably just dry and shrank a bit. When you let off the throttle is when the engine generates high cylinder/manifold vacuum, and oil will get sucked into the cylinder past the valve guide seals. Not to worry.
    Castle Rock, CO
    304
    Thanks, just being paranoid I guess, it will be at HPR tomorrow!
    #91 Triumph 675
    In the unlikely event that Glenn is wrong... please make sure there are no holes or cracks in your belly pan... :lol:
  1. The right way or wrong way, is there really a 'right' way?
    By Clarkie in forum General Discussion
    Last Post: February 25th, 2011, 07:06 PM
  2. Bikini Bike Wash@Grand Prix Bike Night,Hooters Wed July 28th
    By JimWilson29 in forum General Discussion
    Last Post: July 27th, 2010, 03:55 PM
  3. Bikini Bike Wash@Grand Prix Bike Night,Hooters Wed June 30th
    Last Post: June 24th, 2010, 09:38 AM
  4. Replies: 0
    Last Post: February 12th, 2008, 04:05 PM
