Thread: 2007 GSX-R 750 Radiator
    85
    I currently have distilled water in my bike from when I was getting i ready for the track. I have since purchased a track bike so its time to put coolant back in. However, I am having a really hard time disconnecting the hose to drain the water that is currently in there. I do not want to yank on the hose and possibly tear it. Does anyone have any suggestions? And yes I already loosened the clamps.
    Lakewood
    458
    coolant drain plug located at the top of the water pump. Fill with coolant, done.
    No need to disconnect any hoses.
    http://www.motopartslist.com
    Buy, Sell, or Trade your used parts and accessories.
    Brad Hampton - RMMM / COSM #206
    The hoses will sometimes get stuck when they haven't been pulled off in a while. Get a big pair of channellocks around the hose, and lightly twist it to break the seal. Should pull off easy after that.
    Better yet and in order to not scare the hose use a scratch awl around the inside circumference in order to break the seal and then simply twist it off.
  1. 00 R6 radiator
    By loujr in forum Wanted!
    Last Post: January 23rd, 2013, 09:58 PM
  2. WTB: R6 Radiator
    By KFinn in forum Wanted!
    Last Post: December 28th, 2011, 06:17 PM
  3. 06-09 r6 radiator $145.00
    By cromer611 in forum Parts For Sale
    Last Post: June 3rd, 2009, 07:40 PM
  4. 03/04 R6 Radiator ?
    By bluedevil in forum Wanted!
    Last Post: February 21st, 2006, 11:44 AM
  5. radiator
    By glenngsxr in forum Wanted!
    Last Post: October 7th, 2005, 04:35 PM
