Results 1 to 9 of 9
Thread: 06 GSXR 600 slipper clutch help
    Oct 2009
    Lakewood
    458
    Okay so a little background.
    Last race of 2010, I went out for the 2nd practice session of the morning and my bike would not accelerate. It felt like my clutch was TOAST. Came in thinking I was screwed, but then I explained the symptoms to Louis Ortiz and his dad said I needed to adjust the slipper clutch.
    Long story short, we took the clutch cover off, adjusted the screw on the slipper so it slipped "less" I think, and the bike was fine for the races. Actually felt more powerful than it did for half the season.
    1. What exactly is the problem with the slipper? And why did it happen so "all of a sudden"?
    2. We checked the clutch plates and they looked fine. Do I need new clutch plates?
    3. Is this something that I need to adjust often?
    http://www.motopartslist.com
    Buy, Sell, or Trade your used parts and accessories.
    Brad Hampton - RMMM / COSM #206
    I'm not a GSXR guy, but you certainly should measure the thickness of your clutch plate stack.
    Senior Member Expert loujr's Avatar
    Aug 2007
    Northglenn, Co
    529
    Brad,
    After I had that same issue and after I got a new clutch my pops talked with Jim Wilson who explained how it works...from what I gather its something you check often.
    Louis J Ortiz Jr.
    L & L Racing #23
    Mad-Moto, Scorpion EXO, Galfer USA, Sol Performance, Pirelli, Vortex, Uber Wheels Photography.
    Oct 2009
    Lakewood
    458
    Quote Originally Posted by loujr
    Brad,
    Thanks Louis. It had been a while since that race and I was pumped with adrenaline so I couldn't remember ANYTHING your dad said!
    Re: 06 GSXR 600 slipper clutch help
    Quote Originally Posted by vort3xr6
    1. Clutch is a wear n tear item like brake pads, tires, etc. The plates wear every time you engage and disengage it. As the plates get thinner, the back torque limiter aka slipper needs to be adjusted via the clutch pressure disc lifters. If not you will continue to get more slip until it gets to a point where it slips when applying the throttle.
    2. You can't visibly look at the clutch plates and determine they are fine. You need to measure the thickness of the entire clutch stack.
    3. I adjust mine every race weekend. Should only take you 5 minutes to do. Adjust the 3 lifters by loosing the locknut and then turning the lifter in until it stops and then back it out 2 to 2 1/2 turns depending on how much slipping you want.
    Aug 2007
    Northglenn, Co
    529
    No problem....I think Jim just explained it a little better...
    Louis J Ortiz Jr.
    L & L Racing #23
    May 2006
    In the garage cleaning the dust off.
    459
    That's the same procedure he had you do. That's cool that's how you adjust it. Pretty easy when you don't drop bolts anyways :wink:
    Is this the same on most slippers or just Suzuki?? Wondering about my yo-yo
    ILLMATIC Racing
    MRA#503
    Aug 2007
    Northglenn, Co
    529
    Yeah once adjusted DON'T drop the bolts :shock:
    Louis J Ortiz Jr.
    L & L Racing #23
    Aug 2007
    Northglenn, Co
    529
    Louis J Ortiz Jr.
    L & L Racing #23
  1. STM slipper clutch tool for '03 R6
    By spideyrdr in forum Wanted!
    Last Post: April 27th, 2012, 03:39 PM
  2. 03 R1 SLIPPER CLUTCH
    By JohnGarc in forum Wanted!
    Last Post: June 23rd, 2010, 07:46 AM
  3. Yoyodyne Slipper Clutch and Clutch Pack
    By Munch in forum Parts For Sale
    Last Post: November 10th, 2009, 08:45 PM
  4. R6 Slipper Clutch - NIB
    By jbird in forum Parts For Sale
    Last Post: June 1st, 2009, 09:08 AM
  5. STM Slipper Clutch Install HELP!!
    By DowntoEarthDental in forum General Discussion
    Last Post: May 27th, 2008, 09:45 AM
