Results 1 to 14 of 14
Thread: Current Class Modifications and New Classes for 2011
    Class displacement and Configuration Limits
    SuperTwins GTU
    • Up to 250cc two stroke
    • Up to 750cc two cylinder, four stroke (excluding Ducati 749R)
    • Up to 995cc two cylinder, air cooled, two valve, four stroke
    • Unlimited displacement single cylinder, four stroke
    Formula 40 Class
    This is an Amateur class designed for any racer 40 years of age or older, as of the day of the event. Class displacement limits are set as follows:
    1) Formula 40
    • Unlimited displacement and origin
    Production 250 Cup Class
    This is an Amateur class designed for any year Kawasaki Ninja 250 (EX250) and the 2011 Honda CBR250R produced for sale in the United States. Only the following modifications from showroom stock are permitted:
    A. Bike must comply with safety standards listed in section 5.2 EXCEPT that the Production 250 Class does NOT require a steering damper. A steering damper, however, MAY be added at the riders discretion.
    B. No engine modifications of any kind are permitted. Engine configuration must remain as delivered from the factory. Rebuilding or refreshing motor with OEM parts is allowed.
    C. The stock airbox, air filter and intake snorkel must remain in place and connected. No modification of the airbox, air filter or intake snorkel is permitted.
    D. Bodywork, windscreen, fairing stay and bodywork mounting brackets may be replaced with parts of unlimited origin. Relieving bodywork for clearance of hand and foot controls, exhaust, and frame sliders IS allowed.
    E. Exhaust system, including exhaust bracket assembly, may be replaced with parts of unlimited origin.
    F. Carburetor jetting consisting of main jet, pilot jet, needle and slide hole size may be changed. No other modifications to carburetor are allowed.
    G. The PAIR valve may be blocked.
    H. Suspension may be modified with different springs, valves, and oil. The stock rear shock body and stock fork tubes must be retained. Preload adjusters may be added to the forks. Rear ride height may be altered or adjusted. This can be done with aftermarket dog-bones.
    I. Brake pads may be replaced with parts of unlimited origin, however, brake calipers and rotors must remain stock.
    J. Brake lines may be replaced with parts of unlimited origin.
    K. Hand and foot controls, rearsets, handlebars, and levers may be replaced with parts of unlimited origin. Brake master cylinders and throttle control must remain stock.
    L. Gearing may be changed by replacement of chain and sprockets only. These parts may be replaced with parts of unlimited origin.
    M. Tires must be DOT rated tires only.
    N. Stock charging system must be fully connected and functional at all times.
    O. Instrument cluster may be removed, and gauges may be replaced with parts of unlimited origin.
    P. Only DOT approved, street legal pump gas may be used. NO race gas or performance fuel additives are allowed. At the MRA's discretion, fuel may be supplied to competitors at the prevailing market price.
    Q. Parts which are not critical to bodywork or integral support may be removed, but they must be removed at the stock mounting or bolting point. Cutting of materials or frame parts is prohibited, with the exception of the kick-stand bracket which may be removed for ground clearance, and the countershaft sprocket cover may be modified or removed to accommodate "GP Shift Pattern".
    R. For Kawasaki EX250’s manufactured prior to the 2008 model year, the following additional modifications beyond stock are permitted:
    (1) Wheels may be replaced ONLY with OEM 2008 and up 17" Ninja 250 wheels or any generation EX500 wheels.
    (2) Rear shock may be replaced ONLY with OEM 2008 and up Ninja 250 shock or any generation EX500 shock.
    (3) Front end including upper and lower triple, forks, and brakes may be replaced with either 2008 and up OEM Ninja front end or any year EX500 front end.
    Thunderbike
    This is an Amateur class allowing superbike modifications to the specifications listed below. The following bikes are permitted to compete but must remain OEM displacement and are the only bikes allowed to be over the displacement limits: Aprilia Mille - PRE-2004 models/ Ducati - 916 and 996/ Honda - RC-51, Superhawk VTR 1000/ Triumph - Daytona 955 and Speed Triple 955/ Suzuki - SV1000, TLS and TLR. Homologation specials exceeding the class displacement limits are excluded from this class. This includes Ducati models with SPS, R, and RS designations if they displace greater than 850cc.
    1. Thunderbike
    • Up to 850cc two cylinder, liquid cooled, four stroke
    • Up to 350cc two cylinder, liquid cooled, two stroke
    • Up to 700cc three cylinder, four stroke
    • Unlimited displacement two cylinder, air cooled, two valve,
    Dec 2010
    Belen, NM
    21
    The Production 250 class.
    With all the Modifications being allowed here - everything is easy to understand except for section F. What is meant by "slide hole may be changed"? Does that mean that we can bore out the carb. to make it a larger size, as long as we use the stock body?
    Section F refers to the hole in the slide only. Since the carbs are CV carbs on these bikes you're allowed to change the hole size in the slide to make it pick up faster. This is a common and simple modification that would be done while jetting. The dyno jet kits used to come with the right size drill bit for the job.
    Does that help?
    Dec 2010
    Belen, NM
    21
    Does that help?
    That sure does help. Most of my racing was very long ago when most of the race bikes were 2 strokes and the others had plain slide carbs. and if the bike came with CV's they were replaced with something that worked. Things have come a long way over the years.
    Just call me old, fat, and slow..
    Hope to see ya at the up coming Banquet and at the races this summer. Living down south here in NM I do have a few track days down at Arroyo and Sandia plus a couple of race days to work on my setup..I hope to get a jump on some of you guys up north.
    As of yet ASMA and SMRI don't Have a good class to race these fun little bikes. Tho SMRI Is thinking about one. Sure would be fun if in the future to Have a north/south 250 cup challenge race. (o'well dream on, old man,dream on)
    Q: Is the change in SuperTwins GTU for 2 stroke displacement a misprint or an intented change? It leaves the TZ250's with only one sprint race (if the bike is older than a 2001), Race of the Rockies (if you're eligible), and Middleweight Endurance. I don't have one, no possibility of getting one, but wanted to point it out.
    Q: Are the singles in Thuderbike allowed to be of unlimited origin since it is superbike based?
    Quote Originally Posted by Scored51
    Singles in T-Bike are unlimited
    Tz250 still permitted in Twins U (misprint)
    I'll have casey fix it up.
    But my NSR500 V-twin isnt?
    Quote Originally Posted by Clarkie
    Aaron,
    That bike has been (I'm sure) wrongfully omitted from this class for years. Unfortunately no member has written a rule change proposal in recent memory to correct this grievous and blatant injustice....
    S
    CONSPIRACY!!!
    I'm sure this is yet another 'Clarkie rule' :roll:
    CONSPIRACY!!!
    OUTED! And I would have gotten away with it too if it hadn't been for that meddling Kiwi.
    I would need a bike with 60hp more that weighs around 60lbs less than the mighty SV just to keep Mohammer-Time in sight!
    Senior Member Amateur Snowman's Avatar
    Feb 2009
    Denver, Colorado
    134
    Or one of these...
    You think this would legal in Formula 40?
    Randall "Snowman" Turner
    MRA No.427 - Honda CBR600rr Fireblade
    Casey, I revised the 250cc limit in STU to continue to allow the TZ's by taking out the words "single cylinder".
    Also, I added the "and the countershaft sprocket cover may be modified or removed to accommodate "GP Shift Pattern" to Section Q as we discussed.
    Is my Peirobon legal for this class?
  1. penske double/zx6 03-current SOLD
    By cromer611 in forum Parts For Sale
    Last Post: October 14th, 2011, 11:10 PM
  2. New Classes and some Changes for 2011!
    By T Baggins in forum General Discussion
    Last Post: December 23rd, 2010, 11:55 PM
  3. Rocky Mountain Mini Moto to add 250 Spec Class for 2011!
    Last Post: November 9th, 2010, 09:56 PM
  4. New Class Proposal for 2011--Formula 40
    By oldtimer in forum Rules & Tech
    Last Post: September 13th, 2010, 07:27 AM
  5. Supersport Rules Modifications
    By rybo in forum Rules & Tech
    Last Post: August 22nd, 2010, 12:17 AM
