First things first you have to know what needle you have, DJ needles have a flat top with 7 clip positions and Factory Pro needles have a 45 degree taper and only 5 clip pos. With that I can get you in the right direction.
I have not done any SVs with the factory kit as at altitude some of their kits don't work well so I use Dyno jet most of the time. Once I get the dyno back up and runnin it would be best to come down and run it to see where its at.
