Results 1 to 6 of 6
Thread: Oleg's Yamaha R6 - must see!
    Junior Member Novice
    Feb 2009
    10
    Serious buyers only, please read the whole ad.
    For sale is my 2008 Yamaha R6 and all the spares. This is a purpose built serious race bike, it is competitive at Pro, national, and definitely club level. This is one of the most built and fastest 600s you will find anywhere, it has almost everything imaginable done to it. Even though this is very fast bike, it is easy to ride. This bike was purchased for racing, it was bought brand new and turned directly into a race bike. It was built by Rocky Stargel (crew chief for Chaz Davies in 2009).
    Bike Specifications:
    2008 Yamaha YZF-R6
    Engine #1:
    - World Supersport spec motor
    - 130-140 hp depending on altitude
    - Custom cams
    - YEC adjustable cam sprockets
    - YEC valve springs
    - Custom exhaust porting
    - Custom intake porting
    - Decked engine case and milled head
    - YEC NGK gapless spark plugs R0045Q-10
    - Custom coated rod bearings
    - Graves emissions block-off plates
    - Clutch with one weekend on it.
    - Graves case covers
    Engine #2:
    - SST and AMA legal
    - YEC head gasket
    - Clutch with two weekends on it
    - Taylormade carbon fiber case covers
    Suspension
    - Ohlins 25mm cartridges with 95 springs, oil has two weekends on it
    - Ohlins TTX rear shock. Fully adjustable. Upgraded rebound valving circuit. This is not an off the shelf TTX shock. Brand new oil.
    Chassis
    - YEC kit radiator ($3300!)
    - Leo Vince WSS full titanium exhaust system (special kit cant normally buy this)
    - Graves fully adjustable rear sets
    - Graves clip-ons
    - Renthal grips
    - Galfer SBK front SS braided brake lines
    - Galfer SBK rear SS braided brake line
    - Galfer full carbon SBK brake pads
    - Graves spec Ohlins steering stabilizer with Graves mount
    - DID EVO ERV3 chain, brand new
    - Graves quick release fairing mounts
    - GP Tech folding clutch lever
    - GP Tech folding brake lever with remote adjuster
    - Renthal and vortex 520 sprockets
    Electronics
    - YEC ECU
    - YEC kit wiring harness
    - Dynojet quickshifter
    - AIM MXL Pista digital dash and full data logger
    - Pit speed limiter switch
    - YEC ignition switch
    - Gyro track mapping
    - Front suspension potentiometer
    - Rear suspension potentiometer
    - Built in lap timer
    - YEC interface cable
    - AIM interface cable
    - Moty Design light weight quick disconnect battery
    Spares:
    - Right now engine number #2 is installed in the bike, I can swap the other one in for the buyer if they want. Either way you always have a spare engine.
    - Extra set of wheels
    - Another set of wheels that are slightly bent but fixable
    - Front brake rotors
    - Radiator
    - Battery
    - Swing arm
    - Sub-frame
    - Stock dash
    - Rear sets
    - Clip-ons
    - Grips
    - Sharkskins bodywork set – damaged but repairable
    - Amour bodies bodywork set – damaged bur repairable
    - Custom foam seat
    - Clutch and brake levers
    - Brake reservoir
    - Front intake
    - Fairing stay
    - Leo Vince titanium exhaust can
    - Cush drive
    - Front and rear sprockets
    - Taylormade carbon fiber case covers (both sides)
    - Graves case covers (both sides)
    - YEC wiring harness
    - Really damaged gas tank
    - Wheel spacers
    - Brake pads
    - 2x windscreens (stock and zero gravity)
    - Air filter
    - Oil filter
    This bike has always been in pristine mechanical condition. After every race weekend it was gone through to the frame to make sure everything is in order. Regular oil changes on the motors (300V Motul oil) and suspension. I don’t want to part this bike out. I want to sell it as one package deal.
    SELLING PRICE IS $13,500 FOR EVERYTHING
    Please contact Oleg @
    oleg.pianykh@gmail.com
    or
    eight zero one – 5608612
    MOM #57
    Senior Member Amateur
    Sep 2005
    Arvada
    424
    My pants just got tight.
    Chadwick
    MRA #825
    Senior Member Expert
    Mar 2005
    The Local Topless Bar!
    2,358
    You done racing Oleg? or just switching things up?
    I will attest folks that this is a good machine. I raced with Oleg for a few years in Utah.
    Jeff Brown, #277
    "What can Brown do for you!"
    2011-2022 New Rider Director
    2008-2010 MRA Rider Representative
  4. #4
    Feb 2009
    10
    Quote Originally Posted by Throttleroller277
    Thanks Jeff!
    I am not sure yet what my plans are for next year. I want to race but I need to find some good sponsors.
    MOM #57
  5. #5
    May 2005
    Firestone, CO
    2,303
    I want to rub on it like a cat in heat... That thing is a weapon and should be against the laaaaaaaw !!! DROOL
  6. #6
    Feb 2009
    10
    Sale pending.
    MOM #57
Similar Threads
  1. Yamaha R6
    By parapuke in forum Bikes For Sale
    Last Post: May 23rd, 2012, 02:59 PM
  2. 99-02 Yamaha R6 Oil Pan
    By dragos13 in forum Wanted!
    Last Post: August 30th, 2007, 03:38 PM
  3. 06' Yamaha R6
    By Throttleroller277 in forum Wanted!
    Last Post: December 1st, 2006, 08:53 PM
