As you may know when it comes to protection, Forcefield is one of the leaders in armor protection. You can trust that if you are wearing a forcefield product it is one of the best in the industry over the past several years.
We carry thier full line in stock!
Forcefield back protectors are always at the top whether it’s the Forcefield L2 or the new Forcefield Pro Sub 4. Either way forcefield back protectors are the best on the market
Forcefield Pro L2
The Forcefield Pro L2 is constructed using Nitrex® a unique high-tech triangular shock absorbing material combined with dense and lightweight layers of foam and conforms to the CE test EN1621-2 Level 2 the highest possible level. The Forcefield Pro L2 back protector is designed to be soft, flexible and comfortable whilst still providing maximum impact protection. Nitrex® also provides Repeat Performance Technology (RPT) to ensure that even after multiple impacts there is no loss of protective performance.
Fully adjustable shoulder straps and double waist adjustment ensure a correct fit for different body shapes.
FEATURES
- Fully CE approved to EN1621-2 Level 2
- Multi Sport back protector
- Breathable and lightweight
- Repeat Performance Technology (RPT)
- Anatomically and ergonomically designed
- Molds to body shape
- Ultra thin construction
- Fully Adjustable
The Forcefield Pro Sub 4 back protector has been specifically designed to test at under 4kn when subjected to the standard CE test EN1621-2.
Independent testing by SATRA shows a mean test result of 3.38kn transmitted energy, making it the first motorcycle back protector in the world to attain this level of performance.
Constructed with a removable & washable outer cover to give the rider the ability to keep the back protector clean and hygenic. It also makes the protector more flexible as it is not bonded at the edges, this in turn makes it more comfortable to wear, a prime consideration in the design process of any Forcefield product.
As with all Forcefield Body Armour® the Forcefield Pro Sub 4 back protector has RPT (Repeat Performance Technology) ensuring continued and consistent protection even after multiple impacts.
FEATURES
- The worlds first Motorcycle back protector to transmit less than 4kn when subjected to the standard CE test
- Removable & washable outer cover
- CE Level 2 Protection - Highest Possible
- RPT (Repeat Performance Technology)
- Comfortable and non restrictive
- Flexible
- Breathable
- Adjustable waist and shoulder straps
- Multi Sport use
Focefield Back protector insterts
The Forcefield Upgrade Back Inserts are designed to replace existing back inserts and are available as either Level 1 (Sport) or Level 2 (Pro) protection.
Using Nitrex® a unique high tech shock absorbing material, energy can be dispersed and absorbed evenly over the whole surface whilst remaining flexible and comfortable.
FEATURES
- Constructed from Nitrex® armour
- Moulds to body shape
- Perforated and breathable
- Flexible
- Lightweight
- Choice of performance levels
- CE Approved
If you need any rider protection just send us a PM or give us a call today and we can get you fitted up with the right Forcefield product at a great price! 303-893-4349
