AKA Q2s baby!
Just letting you guys know that if you are planning on heading to the track and need a new set of street tires anyway (cough, cough super street guys).. Think about a new set of the Dunlop Q2s.
The new Q2 incorporates race-tested advancements that add up to a vastly superior tire equally at home on the street or the track.
- Intuitive Response Profile (IRP) technology in the rear tire intuitively allows the rider greater latitude in line choice while cornering and provides amazingly linear steering no matter what shape, speed or camber the corner, and at all lean angles.
- Radical new profile puts down a bigger footprint at extreme lean angles while also allowing greater lean angles and higher corner speeds to provide substantially better grip and handling.
- Dunlop’s advanced Multi-Tread technology combines the benefits of a tough, long-wearing center compound for increased mileage with a special lateral-grip compound on each shoulder for superior cornering traction.
- New carcass construction in both the front and rear tires includes newly designed continuous hex beads that are both lighter and stronger to enhance steering response in the front tire and increase cornering stability in both tires.
- Q2 rear tire features a newly developed, stiffer version of Dunlop’s Jointless Band (JLB) construction that utilizes a continuously wound aramid belt for reduced carcass distortion, plus stiffer overall construction to meet high-performance demands and provide a more consistent contact patch.
Prices:
120f 180/55r: $209.95
120f 190/50r: $200.00
120f 190/55r: $225.95
Includes free mounting.
I will have these tires stocked at trackside so contact me if you would like to run a set!! (720.323.6162 begin_of_the_skype_highlighting**************720.3 23.6162******end_of_the_skype_highlighting)
