Results 1 to 15 of 15
Thread: Supersport Rules Modifications
    The following supersport rule modifications have been proposed thusfar
    Quote Originally Posted by sheispoison
    Add Rule:
    2.2.2.B The following items may be added or replaced with other than OEM parts:
    a. Case guards.
    b. Fork brace.
    c. Fire retardant foam. Foam may be installed in fuel tanks.
    d. Steering damper.
    e) Standard and slipper clutch assembly (steve g.)
    f) Windscreen(carl s.)
    (carl s.)
    The question I have to ask in this situation is at what point does a supersport bike become a superbike? We already allow brembo master cylinders in supersport, which most clubs don't allow.
    When I was thinking about it a couple years ago (when we had a big supersport rules BLOWOUT) I was thinking that if I alone were making the rules I would stop at the point where major mechanical items were being changed. This would include things like the clutch and master cylinder, as both can have a major impact on the performance of a motorcycle.
    An aftermarket clutch, slipper or otherwise, can greatly reduce the rotating mass attached to the crankshaft, and therefore makes a difference in the performance of the motorcycle. Should we also allow reduced weight flywheels? It bolts on just like a clutch. How about eliminating the charging system? What about removing the crankshaft, and lightening / balancing it? I realize that I'm not racing supersport and shouldn't care too much, but really, at what point does a supersport bike become a superbike? I would likely vote against this change.
    The windscreen.....I'm not sure that I can see how it matters one little bit. I just can't see how an aftermarket windscreen could offer a major competitive advantage. (even if it does, the advantage would be minor compared to that of a slipper clutch), so I would likely favor this change.
    Another thing to consider as we make supersport rules is how it affects our ability to host riders from other clubs. If we put our rules too far out of line with those of other clubs, then those racers may not come race with us. On the other side, we may prevent ourselves from being to go and race with other clubs as our bikes wouldn't be supersport legal there.
    My .02
    I was thinking the same thing about the slipper clutches, I don't know if those are legal anywhere else but I would bet not. I kind of thought Grubbs was joking about the suggestion? :wink:
    For Double Bubble windscreens: CCS Supersport allows them, WERA Superstock does not, don't know about MoM series but they usually line up with us.
    Aug 2006
    575
    I think they should only be allowed in CBR 600RR's and triumph 675's.
    Quote Originally Posted by racedk6
    Why not other machines?
    A rule change like this one is hard to enforce.
    Taking it to the extreme: "Only people named Steve must start the race with less than 2 gallons of fuel in their tank, but only when riding a kawasaki with pirelli tires. In that case 2.25 gallons is allowed, but oil must be 10W40."
    The rule either applies to the whole class or it doesn't.
    I thought you didn't want a Triumph anymore? :wink:
    Aug 2006
    575
    I suggested the rule for bikes that dont come stock with a slipper clutch.
    And Wyeth I dont want one anymore!
    I propose that if you are under 120lbs wet, like Grubbs, that you are required to carry a backback filled with 50lbs of lead or ballast.
    Quote Originally Posted by UglyDogRacing
    only in supersport? or in all classes?
    If you are going to make SS more and more like SB, then just do away with SS classes and make them all run what ya brung. SS to me means body work, case covers, clip ons, rear sets, Exhaust/Air Filters/PC's, brake lines, DOT's, and suspension internals. Everything else stock as made for that model that year.
    Quote Originally Posted by bluedevil
    The goal of supersport rule changes, imo, should be to make it less and less expensive from year to year - not more and more expensive.
    Additionally, if we nuke the SS classes altogether - that's one less class for people to race in each weekend and thusly that much LESS revenue for the club.
    Just like if we nuke RORU :shock:
    Quote Originally Posted by TRK
    I couldn't agree more... which is why the Board went AGAINST the rules committee recommendation to go with a single ROR. That would have further cut the participation...
    Its not a suggestion to "nuke" RORU, but rather combine RORU and RORO
    I agree, I just see windscreens as bodywork. That's why I said it. As far as slipper clutches go, if it didn't come with one then I see it as superbike upgrade.
  1. Aragon Supersport
    By jmaher in forum General Discussion
    Last Post: July 10th, 2012, 03:43 PM
  2. Current Class Modifications and New Classes for 2011
    By dragos13 in forum Rules & Tech
    Last Post: May 5th, 2011, 08:55 PM
  3. world supersport
    By jdub in forum General Discussion
    Last Post: March 16th, 2010, 11:28 PM
  4. Supersport question
    By gpsigs in forum Rules & Tech
    Last Post: March 27th, 2009, 05:01 PM
  5. Supersport Rules for 2009
    By T Baggins in forum Rules & Tech
    Last Post: September 28th, 2008, 08:30 AM
