Results 1 to 2 of 2
Thread: Yamaha R6 for sale $3500
    2
    Contact 719-217-7669
    $3500 OBO.
    2003 Yamaha R6 custom build, maintained, safety wired and raced by Danny Anderson #4 (#445). This is very fast 03 bike that is ready to race. Windscreen has left top corner broke off and tail section needs some TLC. There are many spares and many new in plastic.
    2003 Yamaha R-6 Race bike
    Full set GP Composite body work including front fender
    Harris upper bracket
    Woodcraft clip-ons
    Renthal grips
    Lockhart 1/4 turn throttle
    Custom ignition switch eliminator
    Custom right hand handlebar run switch
    New Yamaha radial pump masterxylinder
    Goodridge dash-2 brake lines
    EBC GFA-HH brake pads
    GPR steering dampner
    Graves throttle slidestops
    Votrex gas cap/aircraft quality heat sheild
    Velocity stacks
    Stomp gas tank grips
    YEC kit air filter
    Ported cylinder head
    Block bored over 2mm
    J.E. Forged pistons 2mm overbore
    Falacon ultralite weight superbike
    Crank is boron nitride coated
    Crank is 2lbs lighter
    Hinson slipper clutch
    APE manual cam chain tensioner
    Woodcraft side case covers w/S.S. skid plates
    Graves full titanium exaust w/TI can
    YEC kit injection block off plates
    Rapid bike fuel management system with quick shifter
    Has 2 map capability with handlerbar switch
    sato rearsets
    520 AFAmM chain and gears 15-48
    Penske rear shock triple
    Race-tech gold valves compression &rebound
    .90 Front springs
    Intuative frame sliders
    Intuative delrin spools
    Meticulusly safety wired
    All hardware is factory Yamaha
    No hardware store bolts and nuts
    Maintained by certified tech and expert racer
    1.6 bar radiator cap
    Manual cam chain tensioner
    Oil changed every other race weekend
    This bike won 2 track lap records 1 for amateur
    1 for amatuer endurance ridden by Danny Anderson
    These records where won in 2006
    These were set at Pueblo Motorsports
    SPARE PARTS
    1- painted gas tank
    1- Full set of gp composite race fairings
    1- radiator
    1-set of custom made 1/4 turn throttle cables
    fuel lines and clamps
    radiator hoses and clamps
    vaccum hoses and clamps
    1-set of renthal grips
    1- customized water overflow tank
    1-factory water overflow tank & lines
    1-front axle
    1-rear axle
    1-factory clutch lever
    3-factory brake levers
    2-factory shifter assembly
    1-thermostat
    1-set intuative frame sliders
    full set of factory shifter forks
    1-factory gauge cluster
    1-factory ignition trigger cover and pickup sensor
    1-factory transmision side cover
    factory fork valves
    clutch springs, bucket, and shims
    multiple factory o-rings
    JE pistons circlips
    1-cut flywheel for running w no charging system
    1-new AFAM 49 tooth rear sprocket
    1-factory subframe panel
    1-set of .95 front fork springs
    spare rearset brackets
    1-front rotors
    the old factory ignition switch
    10
    Do you have any pics of the bike?
  1. 06 zx10r race/track bike for sale cheap $3500
    By jwt777 in forum Bikes For Sale
    Last Post: October 13th, 2013, 02:20 PM
  2. Yamaha R6 for sale-Good Condition
    By Shyman in forum Bikes For Sale
    Last Post: November 30th, 2011, 10:51 AM
  3. Replies: 4
    Last Post: May 28th, 2010, 01:02 PM
  4. 2 yamaha yfz 450's for sale
    By Edda Tully in forum Bikes For Sale
    Last Post: February 8th, 2009, 08:21 PM
  5. Yamaha Banshee for sale
    By csmith in forum Other Items For Sale
    Last Post: July 25th, 2005, 02:06 PM
