Results 1 to 10 of 10
Thread: re-gearing chain question
    Jan 2010
    Arvada
    70
    I am switching the gearing on my gixxer and going to a 520 chain. In the past, I have cut the chain off and used the master link to put the new chain on. Can you run removable master links in the MRA? Do I need to go buy a chain tool?
    Re: re-gearing chain question
    Quote Originally Posted by motolitho
    Can you run the clip type master: YES
    Should you run the clip type master: I personally wouldn't.
    If you need a chain tool, you can usually find someone in the pits that has one you can borrow. Or head to your local motorcycle store (I suggest Vickery) and purchase one.
    Not going to say that people don't successful run a clip type master, I just don't like the risk.
    Chain tool is great to have. Just dont let anyone borrow it. Most dont know how to use them and they come back broken. I have this one and it does it all - http://www.amazon.com/RK-CHAIN-CUTTE.../dp/B000GZOI48
    Jan 2010
    Arvada
    70
    Thanks Jim and Casey. I will go buy a chain tool.
    -Chris
    Or use a clip link, loop safety wire around the outer plate and clip, then silicon over it. It's how we wired GP bikes and the Aprilia Cup bikes. I chain tool is a great investment as well, safety wire and silicon is just cheaper
    Jan 2010
    Arvada
    70
    I found a chain tool to borrow but have no idea how to use it. ops: I have the new sprockets on and the chain cut to the correct length- now the fun part- the new chain does not come with a master link, just a link that needs to have the pins rolled or flared. The new plate is not easily slid over the pins- so I am assuming that I will need to use the tool to press it on (then use the punch to roll the pins?)? I'm an idiot.
    If you are at the track tonight or tomorrow morning I can help you with it.
    Jan 2010
    Arvada
    70
    May 2006
    In the garage cleaning the dust off.
    459
    Can I put a rear sprocket one or two teeth bigger without changing my chain?? Its a 520 with a 49 on the rear now.
    ILLMATIC Racing
    MRA#503
    Aug 2006
    575
    Quote Originally Posted by N1K
    Depends on how much room you have to adjust.
  1. NGTU PPIR - Race video and gearing question
    By t_jolt in forum General Discussion
    Last Post: June 8th, 2012, 09:09 AM
  2. cleaning chain
    By jeff healy in forum General Discussion
    Last Post: November 1st, 2011, 04:32 PM
  3. 06/07 R6 Chain Guard
    By bluedevil in forum Wanted!
    Last Post: February 16th, 2010, 09:50 AM
  4. 525 CHAIN NEEDED!!
    By spitfirekid57 in forum Wanted!
    Last Post: March 16th, 2009, 07:42 PM
  5. ANYONE GOT A 525 CHAIN FOR SALE???
    Last Post: February 12th, 2009, 11:58 PM
