Results 1 to 3 of 3
Thread: transponder location?
    Idaho Springs
    50
    does it matter which fork it goes on, and how far down the fork tube does it need to be?
    thanks
    Scotty M
    Scotty Martinez
    #639 '03 749s
    I can't figure out how to post the link from the Tech forum, but check the Transponder location question there...with a pitcure!
    Generally, doesn't matter with fork leg and between the clamps is a good spot. Just make sure the steering lock isn't affected in either direction.
    Good luck Saturday.
    Tom
    MRA #416
    It was under Rules and Tech titled as per below. I used the search function for 'transponder'
    "Transponder mounting question"
    http://forums.mra-racing.org/viewtop...ht=transponder
  1. Cal's Liquors New Location in Byers
    By The GECCO in forum General Discussion
    Last Post: March 26th, 2011, 08:20 PM
  2. Monthly Meetings - NEW LOCATION!!!!!!
    By Throttleroller277 in forum General Discussion
    Last Post: July 15th, 2008, 04:33 PM
  3. New Location & Pre-Season Sale!
    By Faster Motosports in forum Supporting Vendor Ads
    Last Post: April 14th, 2008, 02:54 PM
