Results 1 to 13 of 13
Thread: Bypassing kickstand switch?
    Jan 2010
    50
    In preparation for Saturday, I was finishing up my bike (K3 GSXR750). I removed the kickstand and knew I would have to bypass the safety switch. I can see the relay under the gas tank and I know I can disconnect the switch and splice the wires running from the relay together, but I'll be darned if it's not like I'm trying to cram a size ten foot into a size five shoe. I just can't seem to find the room to work in there!!! Is there any way to bypass the switch that doesn't involve removing the entire gas tank?
    266
    I don't know what wires they are or what it looks like but instead of cutting and joining the wires, is there a way to put a paper clip or another wire between the pins on the relay that those wires go to??
    Hope you got what I mean and it's possible. ??
    Also, instead of working under the tank, can you work with the switch towards the bottom of the bike where the kick stand was?
    Good luck!!
    Oscar
    Zach,
    Taking the tank off really isn't that big of a deal, it should only be a few bolts and you should be able to tilt it up enough to work under it.
    Oscar's suggestion is a good one, you can make a jumper using the plug and a piece of wire instead of cutting and splicing. If you go the jumper route I strongly suggest using the stock plug and not a paper clip or the likes as if it falls out on track you're pretty well screwed.
    I've never done this on a GSXR, but know that on the R6 the same thing had to be done and I just made the jumper. The location on the R6 was under the seat.
    See you tonight!
    Jan 2010
    50
    Quote Originally Posted by Sol Performance
    Good luck!!
    Oscar
    The only problem with trying to put a paper clip or something in the relay is that I'm still having to work under the tank.
    As far as working at the bottom of the bike, I have no idea if I can just work with the wires leading from the relay to the actual switch. If so, that wouldn't be bad at all.
    Can you disconnect the plug right at the kickstand where it connects to the sensor? Maybe you can just cut and splice the wires there. If this is a full time track bike, cut the wires and solder together. Should be all good.
    I have a plug for the suzuki harness that already loops that you can put on to eliminate the switch. It takes 2 minutes to do.
    266
    That Jim guy is alright.. :P
    Otherwise, I will try to bring some wire and a solder gun in case something similar happens to someone else at the track.
    See you guys tomorrow!
    Jan 2010
    50
    Quote Originally Posted by UglyDogRacing
    Awesome! Jim, will you be at the school tonight? How much for the plug so I can bring some cash with me? Thanks!
    If you want you can also bring down your switch and I can make you a loop plug during the school.
    Quote Originally Posted by CaneZach
    You can have it. I'll look for it this afternoon and bring it tonight.
    Jan 2010
    50
    Jim, many thanks! I'll see you tonight.
    And thanks to everyone who took the time to answer. All the replies are greatly appreciated!
    Sep 2008
    78
    CaneZach, if I think your bike is the bike that I think you bought from a local racer, then it should already have the switch bypassed. If it is not the bike, then I will just shut up but can still help you bypass it if needed.
    Elden (The Superchink)
    MRA #415 representing the Bay Area!!!!
    --02 GSXR 600--/--03 XR5iddy--/--06 CRF250r /
    --04 Kymco Vitality Scooter !!!!!!
    Jan 2010
    50
    Quote Originally Posted by eklew
    Elden, it's not the bike you're thinking of. This was my street bike before t became my racebike. Jim hooked me up with a plug to bypass the switch.
  1. 01-03 GSXR kickstand and bolts
    By giovannir6 in forum Wanted!
    Last Post: April 12th, 2009, 12:16 AM
  2. WTB a kickstand for a 1998 GSXR 600
    By dlabout in forum Wanted!
    Last Post: September 4th, 2008, 02:40 PM
  3. Kickstand for XR400
    By rforsythe in forum Wanted!
    Last Post: November 1st, 2007, 10:53 AM
  4. KickStand for F3 ..
    By shaneboone in forum Wanted!
    Last Post: June 28th, 2007, 01:03 AM
  5. '05 R1 OEM Rearsets w/ Pedals and kickstand
    By yzfr1grl in forum Wanted!
    Last Post: March 1st, 2007, 10:03 PM
