Results 1 to 10 of 10
Thread: Clutch Help 2003 R6
    May 2006
    In the garage cleaning the dust off.
    459
    Clutch Help 2003 R6
    Clutch felt as if the bite point when doing starts was gone.The last couple starts have gone like I couldn't not feel it grab like I had been then bam it would grab hard and the front would go skyward. So Ive never changed the clutch since new and the bike has 17k or 18k or so on it so I planned on doing so. I've taken the old one out and the steels do have some marking on umm but not to bad and the fibers are worn but still have some material on umm. What I have found is a little bit of wear on the basket some groves and what i would call the pressure plate spring studs have some deep groves on them some deeper then others on both. Now what does this mean? Would this of been the cause of the problem or what would this have been causing ? Is this common? What would you do now? Could the clutch feel be a simple as differant oil and the rest is still good?
    ILLMATIC Racing
    MRA#503
    I raced 03 -04 r6's for couple years. Give me a call and we can discuss, or depending on where you live, I can come check it out, and give you a hand. 303-210-0425
    2,876
    FWIW, I've found that as a clutch nears the end of it's life it does exactly what you describe - it's hard to modulate, acts more like a switch.
    Visually, there is very little difference between a worn friction plate and a new friction plate. The difference in thickness between the two is very small, but adds up over the depth of the stack. So, just because it "looks" ok, doesn't mean it is.
    After 18k miles, I'd say to replace the steels, especially after a few race starts. It's not that much additional cost, and since starts are SO critical, it's money well spent.
    Lastly - BUY AN OEM CLUTCH! They're the best, hands down, period, enough said.
    As for the other problems, you'll have to post some pics or let Jeff take a look and advise you. He knows his stuff.
    The GECCO
    You begin your racing career with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
    Littleton, Co
    1,659
    PM sent
    May 2006
    459
    Quote Originally Posted by Throttleroller277
    Cool right on Brown! I'll call you tonight I work till 8.
    Thanks Glenn. thanks Casey
    Hearing you say that about how they act before they die helps me forsure. I feel a little better in that it will be ok cause thats the only problem I was having. Now I've bought a barret clutch what do you guys think on umm??
    ILLMATIC Racing
    MRA#503
    2,876
    Quote Originally Posted by N1K
    Not being a smart-ass, but can you return it? Seriously, I've tried three different aftermarket brands of clutches (Barnett was one, I assume that's what you meant?) and the OEM clutches are far better than all the others put together. If you can return it w/o taking it up the backside, do it, and get an OEM clutch.
    The GECCO
    Littleton, Co
    1,659
    I'm with Glenn and only run OEM.
    Firestone, CO
    2,303
    Agreed with G and C.
    Barnett Clutches on my Yami didnt seem to have any feel to them and went down hill fast.
    If you can return, do it, Il ditto the OEM on Yami Clutches.
    Apr 2009
    Aurora
    234
    Just currious by why not go to a sick slipper clutch since his OEM is fried? Or am I talking about different parts?
    #176
    2,876
    Quote Originally Posted by nwatkins176
    That's a pretty hefty investment compared to just replacing worn disks. Needs a new basket, etc.
    The GECCO
  1. 2003-05 R6, 2003-09R6s Parts
    By Eshber in forum Parts For Sale
    Last Post: July 21st, 2011, 02:11 AM
  2. Yoyodyne Slipper Clutch and Clutch Pack
    By Munch in forum Parts For Sale
    Last Post: November 10th, 2009, 08:45 PM
  3. 2003 r6 slipper clutch wanted!!!
    By DowntoEarthDental in forum Wanted!
    Last Post: May 12th, 2008, 09:25 PM
  4. clutch
    By Phat-X in forum Wanted!
    Last Post: May 31st, 2006, 10:18 PM
  5. 2003 r6 left (clutch) stock handle bar???????
    By Fairbanks in forum Wanted!
    Last Post: June 15th, 2005, 10:21 PM
