314 Miles
54 Hours Riding Time
Sunset Red
760cc Twin Cylinder EFI Engine
On-Demand True All-Wheel Drive (AWD)
Legendary Smooth Independent Rear Suspension (IRS)
1,500 lb. (680 kg) Towing Capacity
Length 83 in. (210.8 cm)
Height 48 in. (121.9 cm)
Width 48 in. (121.9 cm)
Weight 770 lbs. (349 kg)
Wheelbase 50.75 in. (128.9 cm)
Ground Clearance 11.25 in. (28.6 cm)
ENGINE & DRIVETRAIN
Engine 4-stroke
Carburetion 40 mm throttle body, EFI
Starter Electric
Cooling Liquid
Transmission P/R/N/L/H
Drive Shaft
Drive System 4x4
Fuel Capacity 4.1 gal. (15.5 l)
OPERATIONAL
Suspension Front: MacPherson strut; 8.2 in. (20.8 cm) travel
Rear: Fully independent, progressive rate with anti-roll bar; 9.5 in. (24.1 cm) travel
Seat Height 34 in. (86.4 cm)
Brakes Front: Single lever hydraulic disc
Rear: Hydraulic rear foot brake
Tires Front: 26 x 8R12; PXT
Rear: 26 x 11R12; PXT
Load Capacity Front Rack: 100 lbs. (45.4 kg)
Rear Rack: 200 lbs. (90.7 kg)
Front and Rear Storage
720.939.7525
http://denver.craigslist.org/mcy/1569402087.html
