$375 OBO
They've been used for two seasons and work great. I can send more pictures upon request.
Use the same exact warmers as Jake Zemke, Miguel Duhamel, Ben Spies, Mat Mladin, Aaron Yates, Josh Hayes, Michael Barnes, Geoff May and other top-level AMA factory racers use!
This is the Mac-Daddy of all warmers!
* Temperature Adjustable with Solid State Micro-Processor and Digital Display
* See actual tire temperature while the warmer runs. Most accurate available on the market.
* Use to set your Hot Tire Pressures BEFORE you hit the track!
* Temperature set point is changed with the push of a button- Range up to 212 degrees F.
* Use higher temps to get ready to hit the track & lower temps for saving Heat Cycles in between track sessions. Safely heat rain tires and different compounds
* Hard Case - this camcorder style case is blow-molded and impact resistant.
* Foam Filled hard case for the Digital Controllers
