Jeff, in my opinion, the start of the race is CRUCIAL to the end result. This way, instead of me being in 4th overall and having to dragrace against 5th and 6th, I get a couple feet advantage to get the jump. When you are racing with really consistant guys (not saying you aren't) then every little bit helps to get to T1 first. On the other hand, if I'm in 6th place, then I dont get to start even with 4th place. They would get a better advantage due to holding a higher point position.Originally Posted by JWinter
If you are gridded in front of Moham, that means you would have more points then him, and must have beat him on the previous race. Since you said he would kick your ass either way, then I dont think this will be an issue 8)
