Results 1 to 7 of 7
Thread: Safety wire front axle tube
    Oct 2007
    Colorado Springs
    113
    Does the front axle need to be safety wired or is the pinch bolts ok?
    930
    yes the axle and all 4 pinch bolts need to be done (assuming there are 4 bolts on your bike)
    J
    2,416
    A quick clarification:
    The front axle NUT needs to be wired along with the pinch bolts.
    On some bikes this means the whole axle needs to be wired (GSXR)
    scott
    Oct 2007
    Colorado Springs
    113
    that's what I have is a gsxr. does anyone have a picture of what i need to do?
    Feb 2006
    737
    This is off an old GSX-R 750 front axle. Start on the inside (closest to the wheel) and lace the two pinch bolts. Finish by attaching your safety wire string to the axle bolt itself. You may need to drill the axle bolt.
    Oct 2007
    Colorado Springs
    113
    Mine is new and the axle is flush with the forks. Do I have to drill a hole in the forks to the axle?
    107
    Even the new GSXR's have the front axle held in place by a short, fat bolt like in Chris's picture above. The bolt needs to be wired, as do the pinch bolts, just like in the picture. Don't forget the pinch bolts on the other leg. Don't worry about the other ("flush") end of the axle.
    Joe Turek #59
  1. Safety Wire Suggestions
    By KevEd614 in forum Rules & Tech
    Last Post: June 15th, 2011, 02:41 PM
  2. ANYONE HAVE AN EXTRA CAN OF SAFETY WIRE
    By spitfirekid57 in forum General Discussion
    Last Post: May 20th, 2010, 10:48 PM
  3. Safety Wire Question
    By peteyt328 in forum Rules & Tech
    Last Post: March 26th, 2010, 06:28 AM
  4. Safety Wire
    By OUTLAWD in forum Rules & Tech
    Last Post: October 16th, 2009, 01:18 PM
  5. Safety Wire???
    By JohnGarc in forum Wanted!
    Last Post: March 21st, 2008, 11:40 AM
