2007 Kawasaki Ninja ZX10R (1000cc)
Lime Green
187 MPH top speed ($100 part will produce 198 MPH)
162 Horse Power at rear wheel
85 lbs. torque
386 lbs. dry weight
Fuel Injected (Mikuni 43mm Throttle Bodies (4)
Slipper Clutch (Traction Control)
4 year factory warranty (transferable)
12,000 miles (avg. 6,000 per year)
All scheduled maintenance performed (receipts)
Michelen Pilot Power 2 Tires (pleanty of tread)
Black Titanium Exhaust
Puig Double Bubble dark windscreen
Frame Sliders (ZX10r stamped)
Swing Arm Sliders (ZX10r stamped)
Bar End Sliders (ZX10r stamped)
ZX10r aftermarket hand grips green/blk
Rim Stripe
Fender Eliminator
Undertail Kit
Shaved front blinkers
Racing fork shrouds
Ignition: TCBI with Digital Advance
Liquid cooling system
Front Suspension: 43mm inverted cartridge fork with adjustable preload, stepless rebound and compression damping adjustments / 4.7 in.
Rear Suspension: Uni-TrakĀ with adjustable preload, stepless rebound and compression damping adjustments, adjustable ride height / 4.9 in.
Front Brakes: Double disc...300 mm (11.8 inches)
Rear Brakes: Single Disc...220 mm (8.7 inches)
Fuel Capacity: 17.03 litres (4.50 gallons)
Thanks
720.939.7525
