The EU1000i super quiet generator is extremely portable (at only 29 lbs.) as well as fuel efficient, running up to 8.3 hours on a single tank of gas when used with the Eco-Throttle feature. This easy starting generator produces only 59dB of sound at 7 meters running at full load, which is less than common speech. The Honda Inverter Generator Technology makes this generator ideally suited for use with sensitive electronics (e.g., computer, printer, and other sensitive electronic equipment) because the inverter generator produces a clean sine wave of energy that prevents surging. To prevent any possible damage to the unit, the Oil Alert will shut the unit off when the oil drops below a safe operating level. The unit also has a DC output terminal for use when charging 12-volt automotive type batteries.
Two like EU series generators can be linked in parallel to increase available wattage through the generator outlets. (Requires optional parallel cable set)
Features :
High Quality, Consistent Power
Super Quiet Operation
Ultra Lightweight for True Portability
Load-Dependent Engine Speed
Electronic Control Unit
Two-Tiered Noise Dampening System
Special High Speed Multi-Pole Alternator
Load-Dependent Electronic Governor
Specifications :
Maximum AC Output (60Hz): 1000 watts
Rated AC Output (60Hz): 900 watts
DC Output: 12V-8.3A
Continuous Operating Hours (Rated Load): Approx. 4.1 hr.
Fuel Tank Capacity: .6 gal.
Dimensions (LxWxH): 17.7" x 9.4" x 14.9"
Dry Weight: 28.6 pounds
Operating Noise (at 7m) (1/4 Load - Rated Load): 52-57dB(A)
