Set of ak-20's will bolt into to 06-07 R6 forks, otherwise can be modified to fit your application, get a jump on the competition today.
Near brand new, only raced twice!
My loss your gain, these retail for $1000!
Heres what they have to say about them
"Traxxion Dynamics is proud to introduce the next revolution in motorcycle suspension! The AK-20 Axxion Cartridge Kit. The AK-20 Axxion Cartridge Kit is a complete bolt-in upgrade that replaces the stock ill-performing springs and cartridges with a pair of extremely high-tolerance CNC-machined cartridges, and top quality springs to youre your needs, weight, and intended use. Our 20mm cartridge tubes are bored and honed to .0005. The 12.5mm cartridge rods are centerless ground to .0005. No other suspension unit is held to these exacting standards. Our unique bearing design helps seal the cartridge to improve low speed damping and increase damping response time, and virtually eliminates stiction. The components are then hard-coat anodized to prevent oxidation and wear contamination of the fork fluid. All of this leads to a cartridge that performs beyond any customers expectation. As an added bonus, the kit is completely modular in construction, and can be retrofitted to future bikes you may buy"
$575 shipped to your door.
