Results 1 to 6 of 6
Thread: direct wire transponders?
    139
    http://www.amb-it.com/motorcycle-rac...s-c-10_12.html
    anyone have one fo these from ANB? says 2 wires to connect and your set, no recharging or maintenance.
    145
    I have one on my Honda
    I can't think of anyone in our club who is running one, but the limitation of this style is lack of transference. So if you run more than one bike you'll need to devise a way to quickly mount the unit on either bike. You'll also need a connector in every bike harness you will be running. The real sticking point is when you have need to borrow a bike. You'll need to create a power harness and install it (possibly when there isn't any time) for the borrowed ride. Other than that, the price difference is simply the cost of the charging kit.
    Hope this helps,
    145
    I'm in invisible mode... :?
    Member Amateur Electroman's Avatar
    Louisville, CO
    74
    I also have a direct wired transponder. It is attached via a polarized plug, to allow me (in the future) to move the transponder between bikes. Direct wiring the transponder removes one more thing to forget about. It's also less expensive. I recommend it.
    Rod Mattison -- '05 SV650, MRA # 26
    STM Suspension, Pirelli Tires, Vortex Racing, EarthX Batteries.
    Quote Originally Posted by jbird
    Sorry, but I usually only remember the ones that cause problems or have problems. Invisibility is a good thing in this case.
    So that's two thumbs up for the direct wire transponders! =D> =D>
  1. Dish or Direct TV?
    By TRK in forum General Discussion
    Last Post: April 27th, 2011, 12:57 PM
  2. I want to get rid of Direct TV
    By GNGSXR in forum General Discussion
    Last Post: February 7th, 2011, 12:26 PM
  3. Direct Lift pneumatic bike/workstand $500
    By turbohoje in forum Parts For Sale
    Last Post: July 8th, 2010, 05:13 PM
  4. Safety Wire
    By OUTLAWD in forum Rules & Tech
    Last Post: October 16th, 2009, 01:18 PM
  5. Safety Wire???
    By JohnGarc in forum Wanted!
    Last Post: March 21st, 2008, 11:40 AM
