Results 1 to 3 of 3
Thread: Final rule changes for 2009
    Jim 'smooth' Brewer
    Ok, this year I'm only 2 weeks late in getting the rule changes finalized and posted.
    http://users.frii.com/jjb/MRA_rules/...al_changes.htm
    Like it says at the end, I'm going to do some minor rewording of protests and procedures but the class rules are now fixed.
    Fountain
    156
    2.2.2.C.13. Brake rotors may be replaced with aftermarket products of OEM material, steel, or iron but must be of the original dimensions. Brake lines and pads may be of any origin.
    So this means I can use my Braking wave rotors or Moto-Master Disks?
    107
    This rule only applies to Supersport classes, which are Expert-level classes. The rotors you have would be OK in Supersport if they are the same diameter and thickness as the original rotors. In any class that uses Superbike rules (the Expert Superbike classes, and all the Novice and Amateur classes), you can use any rotor you want.
    Joe Turek #59
  1. Rule change schedule for 2009 - Rule Committee date & ti
    By Jim 'smooth' Brewer in forum Rules & Tech
    Last Post: December 22nd, 2008, 11:44 AM
  2. Rule Change Suggestions for 2009
    By dave.gallant in forum Rules & Tech
    Last Post: November 22nd, 2008, 08:46 AM
  3. Final rule changes for MRA 2007 season
    By Jim 'smooth' Brewer in forum Club Announcements
    Last Post: December 9th, 2006, 10:13 AM
