Results 1 to 25 of 36
Thread: Supersport Rules for 2009
    I'm starting a thread to address what should and what shouldn't be legal for Supersport in 2009. I have no opinion in the matter, but since that seems to be the basis for the big fuss I thought we should open it up. Go ahead...
    1,638
    I have no stake in the game either, but something I wrote in the other thread based on Crash's assessment that welded frames are not SS legal (paraphrased):
    Welding of frames should be allowed insofar as what is necessary to return the frame to a safe, ridable condition, provided that repair and use does not remove any material that existed when new. If non-structural pieces (mounting tabs, for example) are broken off, they can be re-attached by proper welding technique provided the broken part is salvaged. Replacing broken pieces with new constructions of non-OEM origin should not be allowed, since this opens the door for frame lightening under the guise of "broken part replacement". I don't see a problem with welding though, since technically you're adding material to the bike assuming all of the original metal is still there.
    Likewise, in the event that a frame is bent but otherwise usable, straightening should be allowed to return the frame to a usable condition provided no material is altered in the process. (I'm not sure this really needs saying since I don't consider straightening bent metal to be a "modification" let alone anything anyone could prove, but Crash thought it was illegal, so...)
    I'm also of the opinion that rain tires should be allowable in SS classes when track conditions before the start of the race warrant, at the rider's discretion. My thinking here is that while STREET DOT's are usable in the wet provided the rider tones it back a bit, the tread profile of most race DOT's makes it pretty scary once you lean over since they will not channel water. The compounds are also not as wet-friendly as their street counterparts. Where I'm going with this is that race DOT's merely resemble the street variants anyway, but are more closely linked to the slick versions of themselves. In the interest of rider safety, better racing and ultimately lower expense from less broken bike pieces, I think the tires should be allowed. Some may argue the expense of a set of rains, but really it's about the same as a good set of DOT's and they last much longer when used properly.
    Even though I was a part of the air duct rule's creation, it's obviously a pain in the ass on all levels. I say strike that, maybe putting something in that only motorcycles that had OEM ducts to begin with are allowed to use them (i.e. no aftermarket Ram Air kits being installed), and that if ducts were OEM-standard than they must be used in SS, but that aftermarket air ducts are permissible. I agree with several who stated that the factories have obviously put way more R&D into the function of those tubes than a bodywork maker would do. If aftermarket tubes (with likely zero performance gain, if not a slight loss) save money and crash better, we may as well allow it just like we allow non-OEM bodywork in general. I know what the intent of the rule was originally, but the execution and interpretation has obviously taken a different path, so it's time for it to go IMO.
    MotoLlama Racing
    www.motolla.ma
    www.facebook.com/MotoLlama
    Twitter @MotoLlama
    Llama Schwag! www.cafepress.com/motollama
    #321! Supported by Western Ambulance, ProRT, Chicane Trackdays, Single Track Mind, Rebellion, Vanmar, Wicked Photos, and my family.
    Apr 2006
    Golden,CO
    546
    I also say eliminate Traction Control Legality. I believe this will create better racing and eliminate another cost.
    Rain tires should be allowed. If the argument is to keep costs down then that is not the result. I have to buy 2 sets of rain tires. 1 for SB racing and 1 avon dot set for SS racing. If non-DOT rain tires were allowed in SS this would actually save money for guys like me trying to stay safe.
    MRA #626
    DARC Racing
    Bridgestone Tires
    Factory Trained Auto Repair
    My SS short list for 2009
    Aftermarket TC system or modification to OEM TC system = NOT allowed
    Slicks = NOT allowed
    Modified DOT tires (Including groving) = NOT allowed
    Re-gearing including kit trannies or aftermarket tranny modifications = NOT allowed
    Aftermarket or non OEM measurement wheels = NOT allowed
    Aftermarket valve stems = Allowed
    Removal/modification of keyed ignition unit = allowed
    Aftermarket front fairing stays or modification of OEM stay = Allowed
    Aftermarket brake lines (front/rear) = Allowed
    Brake pads of any origin OEM or aftermarket = Allowed
    Aftermarket Rearsets/foot controls and modifications = Allowed
    Aftermarket chains (including change in size/length), and sprockets = Allowed
    Air intake system modification (including rerouting or elimination of OEM parts and hoses) = NOT allowed
    Smog block off plates = NOT allowed
    Aftermarket and or addition of Non OEM spec. Velocity stacks = NOT allowed
    Aftermarket CAM Chain Tentioner = Allowed
    OEM or Aftermarket Air filter = Allowed
    Aftermarket RAM air intake tubes = Not allowed
    Sealing of any gaps, creases, or removal or any OEM plastic blockages in the path through RAM air duct to Air box = Allowed
    Aftermarket Exhaust headers and pipes or any origin = Allowed
    Aftermarket lever (brake and clutch and clutch perch) = Allowed
    Modification or aftermarket rear shock = Allowed
    Aftermarket Front forks, brake calipers = NOT allowed
    Aftermarket or modification or front fork internals = Allowed
    NO Air filter (Unless OEM specs for that model requires) = NOT allowed
    Aftermarket / cut or drilled Front Rotors = NOT allowed
    Aftermarket Mastercylinders = Allowed (based on the fact that most OEM masters are not up to par for street riding much less racing)
    Cut or drilled Rear rotors (with OEM diameter measurements) = Allowed
    Crank Case breather hose modification or re-route = NOT allowed
    Porting or polishing of any internal engine part = NOT allowed
    Aftermarket or NON OEM spec cylinder = NOT allowed
    Relocation of OEM steering dampers = Allowed
    Data logger or onboard system management and data tracker = Not allowed
    Timing units both IR and GPS = Allowed
    Onboard video/still picture system = Allowed
    Double Bubble or aftermarket windscreens measuring more than 1/4 inch vvariance from OEM height dimentions = NOT allowed
    Aftermarket windscreens of OEM dimentions - Allowed
    1/4 turn or race throttle tubes and cables = Allowed
    Aftermarket or Modification of upper/lower tripple clamps = NOT allowed
    Aftermarket or modification to (including adding or removal of metal (to include polishing) or non OEM Cranks = NOT allowed
    Degreeing of OEM Cams )with out removal or modification to OEM parts) = Allowed
    Powercomander/ Ignition modules = Allowed
    Quickshifters = Allowed
    Kit or aftermarket ECU and wiring harnesses = NOT allowed
    Modification to Air fuel main jet (on carborated machines) = Allowed
    Aftermarket Rods and crank bearings, Springs, valves = NOT allowed
    Aftermarket or modified Radiators and Radiator hoses (with the exception or protective caging) = Not allowed
    Aftermarket or relocation of radiator overflow catch can = Allowed
    Modified charging system or replacement with any aftermarket charging system = NOT allowed
    Battery replacement with battery of any origin/ size = Allowed
    Aftermarket wheel bearings of same materials as OEM spec = Allowed
    (Ceramic Wheel bearings) = NOT allowed
    Repair of a damaged Subframe / swing arm/ frame OEM specs = Allowed
    Modification or original specs or reduction of weight to Subframe / swing arm/ frame = NOT allowed
    Aftermarket Swing arms = NOT allowed
    Aftermarket subframes = NOT allowed (Mainly due to extreme weight reduction and thus significant perfomance enhancement)
    Fuel/oil of any origin or manufacteror = Allowed
    Aftermarket Fuel caps = Allowed
    Aftermarker Fuel Tanks = NOT allowed
    Superbike Seats and tail sections = Allowed
    Exhaust wraping headers = Not allowed
    Exhaust wraping any portion of exaust pipes that come in contact with Rider = Allowed
    Dec 2005
    142
    I would like double bubble windscreens allowed. They are much easier to come by locally (and possibly cheaper) than a factory replacement, or factory spec windscreen, and in my opinion they really wont effect race outcome.
    I otherwise agree with dion's list.
    +1 for Dions list, however I would like the use of aftermarket brake rotors, as long as they stay the same overall size (ie using stock sized floating wave rotors, as long as they do not increase overall diameter)
    Apr 2006
    Golden,CO
    546
    My stock windscreen for my 08 GSXR 750 was $60 from suzuki. Plus the OEM windsreen is way stronger than aftermarket windscreens.
    MRA #626
    DARC Racing
    Bridgestone Tires
    Quote Originally Posted by bluedevil
    TC = NOT allowed
    while I dont dissagree, you know you have just eliminated the 08 ZX10 right, and you would also elimitate the powercommander/Bazzaz units etc
    Quote Originally Posted by Clarkie
    TC = NOT allowed
    Thats why we are here... How do we word it correctly so as not to eliminate an OEM part, yet still maintain a fair level of competition ?
    Perhaps : Aftermarket TC system or modification to OEM TC system = NOT allowed ?
    all of my list ofcourse need to be carefully worded but this is a quick and dirty short list to get the ball rolling...
    295
    Here it is again!!!!!
    G. Only DOT tires may be used.
    4. Grooved DOT’s are allowed for wet conditions. Trimming tires for
    clearance purposes is prohibited.
    Please, please, please for the love of all that holy please let's start allowing rain tires in SS if the race is deemed wet (this should be up to the TM). Next season we may well have four race tracks to race at. On three of them we should be able to race in the rain. We can argue about safety, cost, Supersport being a stock class but why don't we cut through the BS. We all come to the track to race, not pussyfoot around turning 1:30 minute lap times in to 2:15 minute lap times because you can hardly lean the bike over. We have a very good chance of racing in the rain next year. Those of you who have never raced in the rain at all and plan on racing Supersport next year should really pay attention to this. Riding around on DOTs on a 185HP SS 1000 is not safe or very fun. Try it on a 125 HP 600 and it is not much better. I don't care what anyone has said in the past, racing dangerous but using rain tires helps us to minimize the risk. Think of it is as for the same reason you wear a helmet. Riding with one is dangerous too, but which is more dangerous, with a helmet or without? I won't ride without one!
    295
    Rules for 2009 Supersport
    Here are my ideas and I think this could make this a lot easier. First, I agree with a lot of what Dion said but maybe we can make it even simpler. One thing that we may want to think about and that is staying in line with the AMA rules. I don't know if I really care but it is something to think about.
    This will be overly simplified but it could look like this.....
    No Engine Mods!!!!!
    Stock Crank (can't touch)
    Stock Rods
    Stock Pistons
    No head work
    Stock Valves
    Stock Cams
    Stock everything inside the motor (clutch plates OK)
    Stock wheels
    DOT tires (except if declared rain race)
    Rain tires (if declared rain race)
    Stock brake rotors
    Stock Master
    Stock air box
    Stock Tranny
    Stock Throttle bodies
    Stock Throttle
    Stock Linkage
    Stock Frame
    Stock Swingarm
    Stock Brakes
    Stock Wiring harness
    Stock sub-frame
    Stock Charging System
    Stock Forks
    Stock Gas Tank
    Brake pads Any
    Air Filter Any (but must have one)
    Rear Brake rotor can be drilled
    Brake lines Any
    Fuel Any
    Oil Any
    Bodywork Any (No Carbon, must maintain stock look)
    Windscreen Any
    Chain Any
    Gearing Any
    Rearsets Any
    Clip-ons Any
    Sparkplugs Any
    Powercammander Any (This includes Bazazz or any FI unit)
    TC Any (So long as you don't have to add sensors)
    Crank Case Breather mods Any (so long as they are safe)
    Camera Any (so long as it is safe)
    Data acquisition Any (so long as you don't have to add sensors)
    Removal of Ignition and Key OK
    Fairing Stay Any
    Exhaust pipes and headers Any
    Fork internals Any
    Shock Any
    Gas Cap Any
    Quickshifter Any
    Steering Damper Any
    Removal of emissions equipment Allowed (must define)
    So, the way I see it the things you do inside an engine are what gains you the most HP. I see the other things as being creative and racing should have a touch of that at all levels. We can't get rid of TC because it is going to be stock on all bikes pretty soon.
    That may all be too simple but I think between Dion's list and this list it is a good start.
    1,638
    Re: Rules for 2009 Supersport
    Quote Originally Posted by clowe
    (list of nearly every part on a bike removed for brevity...)
    So what you're saying is I can run that super trick carbon fiber ignition kill switch for weight savings, right? :P
    Can you be a little more clear on this one? Adding sensors to what? It could be construed that the DA unit itself is a sensor. Are you saying that even measuring something like suspension travel (which is clearly an added part) shouldn't be allowed? Or was this more thinking along the lines of adding engine sensors, modifying parts permanently, etc?
    MotoLlama Racing
    www.motolla.ma
    Twitter @MotoLlama
    Dec 2005
    142
    Quote Originally Posted by Tumbleweed
    But it is usually an order item. Its much easier to find the DB windscreens local. And really what this comes down to is that I really could care less who is using one, in my opinion it isn't a big deciding factor of race outcome.
    (This is to be taken completely separately and unrelated from arguing anything regarding running them illegally this year, the protests, etc)
    TC = NOT allowed
    yeah that would work 8) but you guys are still overestimating the advantage of TC units, if they were the 'magic button' everyone that has TC would win right? :wink:
    Don't any of you guys (or gals) have jobs, kids and other hobbies, this is waaaay out of control. $50 bucks to the person who brings sanity back to supersport racing!
    1,638
    Quote Originally Posted by Jon
    Those people left to race SB instead a while ago...
    MotoLlama Racing
    www.motolla.ma
    Twitter @MotoLlama
    parker,co
    293
    Only allow
    Fork internals
    rear shock
    Pipe,
    rearsets
    clip-ons
    bodywork/incl. mounts/any source windscreen
    steering damper
    Fuilds from any source
    brake lines
    any pads
    Stock seats
    case covers
    frame sliders
    DOT race tires
    Thats it...
    limit everyone what can be done, reduce cost, close up the racing
    Quote Originally Posted by TBSgraphics
    Only allow
    Fork internals
    rear shock
    Pipe,
    rearsets
    clip-ons
    steering damper
    brake lines
    any pads
    Stock seats
    case covers
    frame sliders
    DOT race tires
    Thats it...
    while I dont disagree, what happens to everyone that currently has they head machined and cams degree'd? You also may as well close the doors to people that come and chase money with the MRA......although I know a lot of people in the MRA dont want them turning up anyway cause they might get beaten :roll:
    just playing devils advocate here
    Agreed but the MRA never really had an open door policy for out of towners to come race with us. I always thought that the club should align themselves more with the majority, CCS maybe but as we don't see many out of towners and very few if any any of the club rarely travel(except for a brief stint to AZ by a few) and our Utah regulars whom have actually aligned themselves with us, maybe the MRA does have room to have SS rules that are unique to this club. By God if we could get it to where nobody bitched about who who's cheaten we really would be getting somewhere.
    I'm just glad I won't have to read the new novel of a rulebook in regards to the supersport classes next year.
    Or, here is an another idea:
    Pitch Supersport into the weeds, just like DMG is about to do.
    You will never be able to stop me from milling my head or doing hand cut valve jobs or even doing custom cam timing by pressing off the sprockets and pressing them back on exactly where I need them to be. Even if the rules say you can't, you won't be able to tell if I did it. Or if Ben did it. Or if Clarkie did it. Or if Bart did it. (That's the argument, right?)
    Everyone is so damn scared of actually having to ride their motorcycle in the MRA that historically we have built the crap out of our bikes as our sole means to beat everyone else (who, ironically are doing the same exact thing).
    So, why not embrace it?
    Pitch Supersport. Superbike everything with stock wheels & forks.
    Viva la Reveolution!
    parker,co
    293
    Quote Originally Posted by MotoSix
    YEAH...
    Classes..
    Nov O, U
    AM O U
    ROR o u
    all bikes and riders will be able to fit somewhere there..
    Make races 20 laps long/ ROR 28
    AND do time Qual for ror each race
    the DMG rules i have seen are SS rules with a Dyno, but yeah bring on the resoutions
    Supersport only in ECU and wheels & forks? I thought internals were free game?
    nope, well not last week it could have changed again :lol:
    the HP class/limit is to allow the BMW's/Buels etc in but limit them, get different strokes for different somethingorothers
  1. Aragon Supersport
    By jmaher in forum General Discussion
    Last Post: July 10th, 2012, 03:43 PM
  2. Supersport Rules Modifications
    By rybo in forum Rules & Tech
    Last Post: August 22nd, 2010, 12:17 AM
  3. world supersport
    By jdub in forum General Discussion
    Last Post: March 16th, 2010, 11:28 PM
  4. Supersport question
    By gpsigs in forum Rules & Tech
    Last Post: March 27th, 2009, 05:01 PM
