Results 1 to 19 of 19
Thread: how to safety wire brake connections
    How do I safety wire the bolts too hard to drill through? I've gone through 3 bits, 2 drill batteries and 1.5 hours of solid drill spinning time to get 1/3 through the bolts holding the front brake lines. I got the hardest bit available for hardened steel and the bits just wear out.
    These bolts have a groove cut on each side so I just ran safety wire around it, flattened the wire on each side of the bolt and it's tight. But I doubt it will pass tech.
    What did you guys use? Any pics?
    Feb 2008
    Denver...ish
    105
    Did you use oil when you were drilling?
    And it does not sound as though that wiring method will pass tech.
    Chris
    "Adrenaline has blocked my fiscal sensibility."
    Quote Originally Posted by turbohoje
    i gather you will be attending the Shellinger Institute of Conquest this summer.
    I finally found a bit that would drill through. I used oil, went slowly, just didn't have a drill press. I was using bits from Ace that wore down faster than the bolt I was drilling. So it seemed I was always making progress but the bits were just getting shorter.
    I think I finally have all of them drilled. I guess I'll find out at tech...
    have you tried using a center punch? it will help hold the bit in place when you first start drilling. also, are the bolts still on the bike or can you take them out and put them in a vice
    Jim 'smooth' Brewer
    What bolts are you drilling? The banjo bolts? If so, we don't have a rule that says you need to wire them - although some other clubs do.
    Now that I look at it, I can understand where there might be some confusion since 5.2.U. says "anything which drains fluid when removed".. but the banjo bolts aren't mentioned in 6.2.3. (I'll fix that for next year)
    So, it's up to Ray, but over the past few years we haven't been requiring brake line banjo bolt wiring. In fact, there are some line/caliper setups where that wouldn't be possible (like the monoblock brembos on my Ape).
    If you're trying to do the caliper mounting bolts, I've been successful with TiNi drill bits and Marty's center punching suggestion.
    some RTV high temp silicone over the bango and washers will pass too
    Dec 2007
    193
    Quote Originally Posted by Jim 'smooth' Brewer
    oh hell yes. 3 less bolts i need to drill
    '13 BMW S1000RR
    '06 GSXR 750 #686. Sold
    By far the best bit Ive used is BluMol (Found at Homedepot)
    dip the tip in some WD-40 and they go through dang near anything you can throw at them... and they cost far less than those over rated higher priced ones..... I can usually do a entire bike with 3-4 of them...
    (Center punch is a MUST)
    Fountain
    156
    can someone give me a quik line up of what bolts have to safety wired? I am coming from Europe and need to make sure I have everything done before shipping my bike.
    Post up what bike and year and I bet someone with the same bike will know exactly what to wire. Beyond that, anything that drains fluid, or has fluid behind it (brass washers), brake bolts and caliper bolts as well as brake pad pins. Also, the radiator cap and oil fill cap.
    There are better posts on this in the tech forum right in the first 10 posts. One post has pics of everything wired on an R6...much more than MRA requires.
    Fountain
    156
    I have a 2006 GSXR600 and am coming in November and want to have to bike ready before it is shipped from Germany if possible. Please post pics if possible.
    Quote Originally Posted by elvis8310@hotmail.com
    http://www.mra-racing.org/PDF/2008_rulebook.pdf
    Sections 5, 6, 14 cover this well. As its been said any bolt with fluid behind it, safety wire it. If in doubt, wire it. Cant hurt to have to many things wired.
    1,638
    Here is the thread with pics that phildrummond was talking about:
    http://forums.mra-racing.org/viewtopic.php?t=6443
    (Spend some time browsing the rules/tech forum, there is a lot of great info in there you will probably want to know as well...)
    MotoLlama Racing
    www.motolla.ma
    www.facebook.com/MotoLlama
    Twitter @MotoLlama
    Llama Schwag! www.cafepress.com/motollama
    #321! Supported by Western Ambulance, ProRT, Chicane Trackdays, Single Track Mind, Rebellion, Vanmar, Wicked Photos, and my family.
    Fountain
    156
    Anyone know were you can buy a safety wire kit? I am looking for a drill guide or something.
    Feb 2008
    Denver...ish
    105
    Harbor Freight carries the pliers and the wire.
    However, aviation supply places tend to carry the higher quality pliers
    Chris
    53
    So for clarification, do banjo bolts need to be wired this year. I've been told by some people that they do, but then I have also been told they don't.
    I know this thread is from last year so I am hoping maybe we can get an "official" (Ray Ray) answer for this season.
    I've got a whole bunch of drill bits just waiting to be broke in half :lol:
    9 Fingers Expert Ray-Ray's Avatar
    Aurora
    1,575
    Quote Originally Posted by CO750
    Banjo bolts are not specifically mentioned in the rule book. Jim needs to add it for next year. I think we forgot!!
    However, this is what the rule book states:
    U. All nuts or fittings which drain fluid when removed, as well as filler caps (except fuel cap) or nuts, and filters must be secured with safety wire or other approved means.
    ANYTHING that has a copper washer behind it needs to be safety wired. These tend to forgotten about.
    Since this is not clear I would strongly encourage you to safety wire them! hint hint hint!! Lets put it this way! If they leak it means you won't stop!
    Ray-Ray Gaimara #16
    2011-2013 Track Marshal RETIRED
    2008-2009 VP of Rules and Tech
    1996-2007 Corner worker/Head Corner worker/Airfence Caption
    2017 Sponsors - Fun Centers Cycle, Ogio, Sol Performance, Vickery Motorsports
    53
    So is there a better way to wire the banjos other than to the lines? I was planning on putting a loop around the brake line fitting and then wiring that to the bolts themselves once they are drilled.
    I really don't want to wire the caliper bolts to the banjos at the bottom and at the master cylinder I don't really see any other way to wire that bolt to anything other than the line itself.
    Aurora
    1,575
    Nope, that is what I do! Safety wire them to the lines.
    Ray-Ray Gaimara #16
  1. Safety Wire Suggestions
    By KevEd614 in forum Rules & Tech
    Last Post: June 15th, 2011, 02:41 PM
  2. ANYONE HAVE AN EXTRA CAN OF SAFETY WIRE
    By spitfirekid57 in forum General Discussion
    Last Post: May 20th, 2010, 10:48 PM
  3. Safety Wire Question
    By peteyt328 in forum Rules & Tech
    Last Post: March 26th, 2010, 06:28 AM
  4. Safety Wire
    By OUTLAWD in forum Rules & Tech
    Last Post: October 16th, 2009, 01:18 PM
  5. Safety Wire???
    By JohnGarc in forum Wanted!
    Last Post: March 21st, 2008, 11:40 AM
