www.water4gas.com
i'm not sure if any folks out there have heard of this, but from 2nd hand info i have heard this works. in short you install a jar of water under your hood and with some electrodes you extract hydrogen from the water. the gas is then run out a line and into the intake on your vehicle. i have read and heard reported claims of 40-50% increases in fuel economy.
so my question is to the motor builders out there, is this B.S. or is there some validity to this theory?
would your ecu be working overtime if you didn't get a steady and consistent stream of hydrogen?
would this make your fuel mixture too lean because you would be pumping in more "air" after the mass air flow sensor?
would this system shorten the life of your motor?
any thoughts appreciated
