Results 1 to 13 of 13
Thread: Dodge Mechanic
    Dodge Mechanic
    I have a 1996 Dodge Ram 1500 that had the check engine light on. Went to the dealer and have 4 DTC's as listed below:
    P0300- Multi Cyl Misfire
    P0301- Cyl #1 Misfire 82 SSS
    P0302- Cyl #2 Misfire 110 SSS
    P0303- Cyl #3 Misfire 82 SSS
    Now, I'm no mechanic but it seems these are related. I was wondering if anyone has any advice, suggestions, connections, etc. I was thinking maybe its a head gasket causing low compression so it doesn't fire? They also say the motor is burning oil. Plugs, wires, cap, and rotor have all been replaced this year. Please let me know if anyone can help. Huge thanks in advance!
    I have a simple explanation for this: It' a Dodge.
    Next time, buy a Ford.
    Also, FWIW, you can go to checker and they'll plug in and pull the codes for you no-charge.
    Not sure if we have any Dodge mech's in the hizzle...
    Feb 2008
    Denver...ish
    105
    Pffft... you got it backwards, T Bag... Dodge > Ford.
    Casey, give my brother Cory a call... tell him I sent you. (1-877-879-3437)
    Chris
    "Adrenaline has blocked my fiscal sensibility."
    Quote Originally Posted by turbohoje
    i gather you will be attending the Shellinger Institute of Conquest this summer.
    Thanks Chris, I'll hit him up later this week!
    In the Pegram racing semi trailer
    1,029
    its not a head gasket because cylinders 1,2,3 are not all on the same side, 1,3 are on one side, and cylinder 2 is on the other.
    Rule out the head gasket.
    You might check for and intake manifold gasket leak.
    But more than likely it's the ignition coil. throw a new one on it, they are cheap, you could even try one from a junk yard for like $20, just for diagnosis sake.
    When a 96 newer vehicle sets a misfire code, it's electrically related, I.E. plugs, cap and rotor, coil.
    the computer has no way figuring out the engine has low compression in individual cylinders, or the engine is using oil or coolant. it would have to be using enough oil and coolant to blow the spark completey out, and if it was you'd see a shit ton of blue or white smoke out the exhaust.
    Check the plugs closely for carbon tracks, or just replace them they are cheap.
    You should also check the injector connections make sure they are plugged in and firing the injectors.
    If you have a scanner, hook it up and monitor the LTFT's on both banks, and if you can report that info back to me that will tell me a whole lot, and I could probably tell you exactly what was happening.
    Positive LTFT's mean the computer is adding fuel, Negative LTFT's mean it's removing fuel.
    So let's say your bank 1 side (cylinders 1,3,5,7) have a LTFT of +25 and bank 2 (cylinders 2,4,6,8.) have a LTFT of -7, this means the computer is adding fuel to bank 1 becuase it's seeing a lean condition on that side of the motor in the account of there being no spark in those cylinders.
    o2 sensors read oxygen content! not Fuel content!!!!, so when a cylinder has no spark there's more air being added to the exhaust system and the o2's read lean, then the computer starts adding fuel to compensate....
    Everyone gets tripped up on this because they think that an o2 sensor read fuel content....it does not!
    A dribbling injector will cause an overly rich condition and your LTFT's will go negative trying to cut down fuel to that side and will cause some cylidners to run too lean and the dribbling one will be rich. this scenario is hard to diagnose properly becuase, there's only one o2 sensor on each side of the motor so you don't know what each individual cylinder is doing.
    Again, I'd really be looking into all the electrical sides of the issue. Like I said earlier, the computer has no way of determining a missfire from mechanical faults....You'll see smoke way before the computer even can think about setting a missfire code.
    MRA #95
    2008 ROR #10
    www.FOXPERFORMANCEENGINES.com
    (719) 570-9595
    Ben, thanks alot for the great response. The truck doesn't smoke and I never really noticed it getting low on oil, that was just the dealers diagnostic that it was burning. I never have to top it off between oil changes.
    First thing I'll do is replace the ignition coil. The cap, plugs, wires, and rotor have been replaced recently. I'll throw in new plugs again while I'm at it also.
    Last, what type of scanner do I need to monitor the LTFT's? I am not too familiar with trucks so sorry if I sound like an idiot. Also, since the check engine light is now off, and the truck "feels" fine, after I change the ignition coil can I test something? Or just wait for the trouble to return or stay away? Let me know. I appreciate all the help with this.
    I changed out the ignition coil as Ben stated and the problem seemed to go away. Everything was running fine for about 3 months and now has returned. I got the check engine light on and the codes again are showing misfire. Same codes as above. Got any ideas?
    9 Fingers Expert Ray-Ray's Avatar
    Aurora
    1,575
    Buy a FORD!
    Ray-Ray Gaimara #16
    2011-2013 Track Marshal RETIRED
    2008-2009 VP of Rules and Tech
    1996-2007 Corner worker/Head Corner worker/Airfence Caption
    2017 Sponsors - Fun Centers Cycle, Ogio, Sol Performance, Vickery Motorsports
    860
    Check the harness for rubbing issues. Maybe its grounding out on the motor. :?:
    Christopher
    MRA 9 (915)
    “I’m just mad because you shouldn’t use the term ‘fag’, Kyle. That’s a hate word, and it’s insensitive to butt pirates.”
    Chris - you're absolutely right. (Mark your calendar, don't think I'll EVER say that again :lol: )
    Sponsored by
    Short Bus Race Team, Vortex, SixSixOne, Faster, VICKERY YAMAHA, Bridgestone, Ferodo, Cycleworks, Rebellion, VP, Motul, MRA, Unink
    Ray-Ray I will take that into consideration (yeah right)
    Chris, let me look around as that could make sense. The problem cleared after replacing the coil for about 3 months. Maybe I moved some wires around, got lucky, and now they are grounding again. I'll check that out tonight.
    Thanks everyone. If anyone else has ideas or suggestions let me know!
    my jeep did the same thing. the codes said misfiring on a few cylinders. I asked my bro in law(the one who did the service on it) and he said he forgot to gap a few of the spark plugs.
    sure enough i pull them and the #6 plug had like 0mm of gap. SOB dropped the plug on the electrode : P
    anyway i gaped them and it doesnt misfire.
    Quote Originally Posted by cromer611
    You "gaped" them?!!??
    http://www.urbandictionary.com/define.php?term=gaped
    Poor sparkplugs... what did they ever do to you?
    419
    OMG! Tony, that was brilliant!
    I did not claw my way to the top of the foodchain to eat my veggies.
    glenngsxr wrote:
    trannies are way different... Glenn #62
    MRA #822
  1. Job opening for A level Automotive Mechanic at FTAR
    By FTAR in forum Supporting Vendor Ads
    Last Post: April 29th, 2013, 10:01 PM
  2. BMW Mechanic
    By Tucky in forum General Discussion
    Last Post: March 23rd, 2013, 11:14 AM
  3. Dodge Ram Mechanic help - Transmission main seal
    By dragos13 in forum General Discussion
    Last Post: June 9th, 2010, 10:11 AM
  4. American Car Mechanic needed
    By ldenvermom in forum Wanted!
    Last Post: February 17th, 2010, 11:51 AM
  5. Toyota Mechanic
    By Wild Cheetah 612 in forum Wanted!
    Last Post: August 19th, 2009, 05:57 PM
